Question about Maytag Performa PAV2200
Very loud squealing noise in spinn.
I have a Maytag Performa washer.  It is about 6 years old.  About 4 years ago it began a very loud screaming noise when in spinn.  I assumed it was a berring so I decided to let it dye a natural death and then purchas a more water efficient unit.  It keeps going and keeps screaming, it sounds like a jet plane taking off.  I took the water pump off and could see nothing stuck in it.  It works fine except for the screaming.  I'm thankful we have the unit in the garage.
What could be the problem?
Thanks,  Jim
  • 5,911 Answers
If your Maytag is a top loader equipped with a vertical transmission under the tub, the squealing may be coming from, either the brake assembly, or the snubber which the entire pedestal rides on.  Could you please post back comments and let me know if this is the type of washer you have?
Posted on Oct 18, 2007
  • Colleen W M Mar 18, 2012
    Hi Jeff- we have a Maytag top loader performa with the same problem, we checked the pump and it looks fine , we tested it before the pump was put back in and it didnt scream, then when we put the pump in and hooked up the belt it did scream. It spins very solid and fast but sounds awful. How do we know look at the brake assembly?
SOURCE:
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Recently our Maytag Performa washer has started
The transmission might be going bad.
Nov 02, 2009 | Washing Machines
During the spin cycle, the machine shakes violently and dances across the floor. It has a loud squealing noise during this. My Performa is only about 14 months old. This is very disappointing for a Maytag.
Look in owners manual. I think these washers have a 1/2 hp. variable speed motor. make sure the washer is level from front to back and side to side, if its not that could be the problem. The motor has a lot of force, the squealing could be a bad bearing not sure.
Aug 24, 2009 | Washing Machines
Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Grinding during the wash cycle
I was told that it was the transmission - good luck with that....
Labor alone was $175 - I ended up trashing mine (3 1/2 years old) and buying a new one.
Just got off the phone with Maytag - by all means, try to get them to pay for stuff before you throw away the one that you have....Now that they know it's gone, I supposedly don't even have the right serial number...(it was hauled away 4 days ago by Lowe's)
Feb 02, 2009 | Maytag Performa PAV2200
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Maytag Performa Washer
Hi brawn253
The oil is comming from the transmission. The only way to fix it is to have it replaced. alot of the orlder machiens have this happen and keep working for many years after. as for the squeal its normal. its just the break some of the oils have got in there and the squealing is a resault of that. I wouldnt be to worried about it.
brent
Sep 21, 2008 | Maytag Performa PAV2200
Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Sep 07, 2008 | Maytag Performa PAV2200
Maytag Performa loud gringding/clicking noise
Mlrescue,YES!
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Jul 09, 2008 | Maytag Performa PAV2200
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Washing Machines Logo
250 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
