Question about Pool & Spa
Dream maker 8003-x500 appears to be in setback mode '56'. How do I take it out of this mode.
3 Suggested Answers
adamh294
  • 310 Answers
SOURCE: motor will not come on.
OH stands for Over Heat situation.
If the motor is not working at all, you are getting the OH code because of that. The OH happens when there is not enough circulation in the hot tub which causes the water near the heater to overheat the sensor located in that area. It sounds like either the pump has failed, the wiring has shorted to the motor, or the control board is not telling the pump to come on.
Its probably a bad motor since the heater is obviously activating, which it wouldnt if the pumps motor was getting no power. Replace motor and all should be well again.
Posted on Apr 14, 2011
Testimonial: "very helpful. @We did not have the sensor connected properly in the panel board. Now it seems to be working fine. Thanks to you."
Coastsider
  • 331 Answers
SOURCE: I have a dreamaker 8003 xspa that has worked perfectly over the many years that I have had it. The other day I noticed that the water had lowered 6 inches overnight an the water was coming out of the
1. Check equipment like pump, heater, blower, light fixture, for leaks.
2. Remove side panels closest to the are the leak is showing and inspect jets, plumbing in that area for leaks. If insulation is foam, remove any water saturated foam and follow it to the source of leak.
3. If the leak is in plumbing and is very slow, sometimes it can be resolved with "stop leak" products.
Posted on Aug 15, 2012
I would like to know if the pump for a dream maker model 8003 eclipse is a side discharge or a center discharge thank you
the very front of the pump is suction, I think what they are referring to is the discharge clocking or how the pump is clocked so looking at the front of the pump does the discharge come out on the right side or left or the top or the bottom, this one pictured is top discharge
Jun 26, 2017 | Pool & Spa
I have the big ez spa I cannot get the SL setting to change and stay on anyother setting.
Hi as you know you are in the Sleep mode of your pump and filter settings. To change the setting to a different setting you must click on the temperature button followed by the light button. This will put you in the filter selection mode once there use the temperature buttons to toggle between the options. For more information you can look to this link. How to change the Filter Mode on Dream Maker Spa
Jun 02, 2015 | Dream Maker Spas Dream Maker Ez Spa Hot...
Model 8003- x - 400 when plugged in motor hums for about 10 seconds then breaker trips(no pump but display lights up
Sounds like the motor is seized. Of it cant turn over it will trip the breaker. Sometimes you can get to the shaft of the motor on the back end by removing a cover or cap. With a large flat screw driver or open end wrench you can sometimes spin it manually to break it free. If it is really stuck the pump may have to be dis-assembled or replaced.
Mar 18, 2014 | Dream Maker Spas Pool & Spa
Aug 07, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I need an Owners Manual for 8003 Eclipse Dream Maker spa. Where can I get one?
I have a 0 on the display, but it still runs but the keypad is disabled
Apr 09, 2012 | Pool & Spa
Motor will not come on. flashing OH on tub display dial. Dream maker Model #8003 x 400 series 86L Just purchased used spa and have no manual or directions. thanks
Apr 14, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
55 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
