Question about Troy Bilt 5.5hp Self Propelled Mower
Troy Built 6.75 Self Propelled to Slow
My self propelled runs kinda slow on the grass, fine on concrete. The mower is only a year old. Can this be adjusted somehow. My older troy built has a very powerfull pull compared to this one.
You have to take off a part behind the gears and move it to a slot farther away. Mine was the same way. It's in the manual on how to adjust the speed to go faster.
Posted on May 30, 2009
  • 749 Answers
Put oil or grease all the shafts and bearings inside and out, if possible adjust the cutter blade contacts.
Posted on May 20, 2009
The belt under the mower that drives the wheels may be worn out or just loose. A new belt or a simple tighten probably will fix the problem.
Posted on May 29, 2009
How does the govener and carb linkage work on a Troy-Bilt 2005 800 Series (839) self propelled mower
Have you changed springs? Likely the correct components are there unless you have changed it. Does it run properly and at correct rpm when not in tall grass? Check for proper throttle adjustment first. also check for obstructions (packed grass for instance) under the deck that could be impeding the blade. Lastly, if you have the discharge blocked with a mulch plug, remove the plug. let the tall grass discharge. then run over it again and mulch it.
May 29, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt XP self propelled mower
Normally an indication of poor air flow. Replace air filter. Clean outside of carb with carb cleaned to ensure choke is free to operate. Go real slow in tall grass, some mowers don't have the torque to do tall grass, only use 1/2 of the deck width and have side discharge open.
May 10, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt self propelled problem
My only guess is you've put the cable actuator in upside down. Sorry, that's the only thing that makes any sense.
Aug 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Engine runs slow and then cuts off on Troy Built 5.5 hp self propelled mower
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
My self propelled mower doesn't fully engauge
What usually causes this is called belt stretch, this happens due the weather and the heat from the engine
Apr 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
840 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
