Question about Toshiba Satellite 1800-S207 Notebook
Battery died I have the laptop plugged in, but it shut down, because the battery died. It told me to switch from battery to electric. Isn't it switched when you have it plugged in?
  • 35 Answers
Hi
Yes, when youconnect the power cord to the laptop it should go over automatically.
what you can do is take a tester and test the power on the powersupply just to make shure you do have power, if you dont have a tester just make shure that youre plug on the powersupply is properly connected
SlitWrists
Posted on May 20, 2009
    Scholar:
  • 106 Answers
Once you connect the cord to a socket yes its automatically switches, could be a bad cord (the cord with the black box on it) and they are not cheap best bet get it on ebay. Hope that helps =)
John Deere Z840A Z-Trak mower. Why does engine die when PTO is engaged?
A possible cause is an open seat switch (operator presence). Locate the switch under the seat & unplug the switch from the harness. Place a small jumper wire into the female socket leads to the wire harness. If the PTO engages without engine shutting down, replace the seat switch.
Check to see if the mower deck is plugged or a piece of wood/debris is wedged between the deck and a blade, or some wire/rope is wrapped around a spindle. If the blades don't turn by hand, it'll stall your engine when the electric PTO clutch is energized.
Lastly, a discharged battery will cause an engine shut down if there's not enough reserve when the PTO is engaged. Measure the battery voltage with a meter. If the voltage is below 11.5 volts, you may have to replace the battery.
Oct 23, 2015 | John Deere Garden
Gateway 6920
The dying hdd cause some problems. Replace the hdd.
Feb 21, 2014 | Computers & Internet
Acer Aspire 5742, Completely Shuts off, error free, randomly.
If your computer is shutting off randomly, there could be a multitude of issues. Most of the issues are hardware related.
1. If you're able to use your computer for a little while, and it randomly shuts off, it could be one of a few things.
a. Overheating processor: You may need to replace your processor, or clean out the inside of the computer.
b. Fans not working: Your fans could be disabled, and keeping the computer from receiving cooling which can overheat the processor as well as other vital components.
c. Dying battery: The battery in your laptop may be going bad, and could need replacement. Does it charge completely, or does it only fill up partially after a long period of charging? If it's the latter, you will need to replace it.
d. Dying hard drive: While this one isn't as likely, and usually doesn't cause the computer to shut off instantly, it's still something to consider.
2: If your computer shuts off before the desktop even loads, it's most likely a hardware problem.
a. Dying battery: Again, your battery may be dying, try removing it and keeping the laptop plugged in when you turn it on.
b. Broken hard drive: Your hard drive may be broken, try finding an external hard drive with Linux or another operating system installed on it, and go into the BIOS when your computer first starts up. Find the "Boot devices" option, and tell it to make the primary boot device the external device with the operating system installed on it. If the computer starts up fine after that, you may need to re-install your old operating system, or replace your hard drive.
May 04, 2011 | Computers & Internet
I have nx9500. No power on response UNLESS 1.) battery is removed and 2.) on/off switch held down for 30+seconds and 3.) AC brick then plugged in. When all this is done and on/off switch pressed, the LEDs...
It would appear from what you say, there is a short on the motherboard. This can cause the adapter to shut down, which it is suppose to do. Unless there is an object in the laptop, the motherboard is damaged and must be repair/replaced.
Please rate this solution.
Apr 07, 2011 | HP Compaq nx9500 Notebook
My 08 gsxr 600 died while I was riding it, I got a new battery and it started up fine, but when I got home I shut it down, then tried to start it up again and it wouldn't start. All the lights are on and...
I would check your connections and grounds. I would check the voltage of the battery with the bike off and then compare it to the voltage when the bike is running to see if the battery is charging. Your may have enough voltage to run lights but not enough amperage to crank. Is the new battery full of acid? silly question but I have seen this happen before, the guy puts the wrong amount in it.
Check your fuses too. I would verify that its charging before trying to chase down any current draws of shorts.
Mar 08, 2010 | 2008 Suzuki GSX-R 600
Notebook shut down and does nto coem back on. No life at all. it has done this isn the past but only lasted a short time. ti acts liekt he battery is dead yet it is never off the wall cahrger.
This could be the cause of your battery dieing and you may have to replace your battery. This happend to my laptop. Try keeping the laptop always plugged in, or replacing your battery, or try contacting geek squad or your local retailer.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 02, 2010 | Acer Aspire 5100 Notebook
1987 Jeep YJ Shutting down
Ignition control module does not control everything electrical. check battery connections at both ends and do some testing to narrow it down a bit...could be a bad ignition switch also but test first!
May 19, 2009 | 1990 Jeep Wrangler
Toshiba Laptop Computer model m45-s265 no power
I would suggest draining the residule electricity from the system and then try switching it on again.  Follow these steps:
  1. Unplug from any power source.
  2. Remove the battery (you will have to flip the laptop upside down and find the lock button that holds the battery in before you can slide it out).
  3. With the battery removed and the power disconnected, tap the power button on the laptop.  Nothing will appear to happen, but in actual fact any residual electricity that has built up across the motherboard will drain.
  4. Plug back in and try switching on again.  If it works, plug the battery in and you're back in business.
If the system still does not work after this, take it in to a repair shop or call your laptop's support service to get more advice, as it could be the motherboard.
Nov 06, 2008 | Computers & Internet
Toshiba Satellite 1800-S207 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
