Savin copier 5002 error code sc899 - Computers & Internet
Henru
  • 45 Answers
SOURCE: Copier reset procedure.
hi fixya180,
It seems that the error code 541 (which indicates a problem with the heating unit thermistor in the machine), cannot be reset by the user for safety reasons, ref;
http://savin.custhelp.com/cgi-bin/savin.cfg/php/enduser/std_adp.php?p_faqid=7081&p_created=1102093227&p_sid=9TrLDc-i&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQzNiZwX3Byb2RzPTI1MTAsMjUxNCZwX2NhdHM9MCZwX3B2PTIuMjUxNCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9ZXJyb3IgY29kZQ**&p_li=&p_topview=1
This error requires service support from your local authorized dealer or original point of purchase. You say that you've verified the functionality of your fuser unit; then a authorized Savin printer technician will probably just have to reset the error code of your copier.
Hope you find this info helpful in solving the problem and thanks for using the FixYa service
Kind regards
Posted on Mar 08, 2008
Cogz
  • 1326 Answers
SOURCE: Savin 2545 copier error code sc541
Hit the yellow botton ( Reset/ CA), then 1 then 0 then7 , then hold down the (Stop) botton till the display changes... Then turn the copier "OFF" then "ON" it may clear the code. The code has to do with your fixing unit.
Posted on Jul 22, 2008
SOURCE: Savin 4090 error code
hi this code means they are no toner in the toner hopper which is attached to the developer unit. hope this helps.
Posted on Jul 26, 2008
Cogz
  • 1326 Answers
SOURCE: savin copier 9400d error code 542
I believe that code has to do with the fixing unit. Try to reset it, press the yellow clear botton once then the #"s 1-0-7 then the red stop botton. The display should change.... turn the copier off then back on.. It should reset the code for you.... Just a question dose it have a finisher on it? If it dose have you tried to unplug the finisher with the power off then turn it back on...Is the code gone..if so you have a problem with the finisher... I work on to many different brands.... Good Luck
Posted on Jan 31, 2009
SOURCE: Error Code 546 in Savin 3540 copier
enter sp mode with the following combination
yellow key then 1 0 7 and hold down stop till the screen changes go to copy sp then scroll down to 7 datalog and down to 897 sc jam reset and execute the turn off the machine and back on
Posted on Mar 13, 2009
How can i clear error sc899-00 on mpc4502. i have updated all he firm and changed I/O BUFFER TO 256KB still it keeps coming up even with out being on network
SC899 codes typically are when people are printing web pages. Make sure all firmware is the most current revision. If it still occurs then there is a special firmware revision on the Ricoh website to remedy that.
Oct 31, 2014 | Ricoh Office Equipment & Supplies
I have a Savin 8035e. I had an error code SC542 and reset the copier as suggested. Worked great. Problem now - How do I fix alignment?
That error code is a dirty fuser thermistor. Clean it and go into service mode then turn off main power switch. That is all that is required. What is out of alignment?
Oct 10, 2014 | Savin Office Equipment & Supplies
Sc899 00
You must clear the print cue. SC899 is from printing from the Internet (typically). With the paper trays open, turn on the machine. Push the Printer button and reset all the print jobs.
You need to update all the firmware on your machine.
Sep 08, 2014 | Ricoh Aficio Office Equipment & Supplies
How do I clear error code SC899?
service tech needs to update the firmware. sc 899 cause by printing of the internet.
Jun 26, 2014 | Ricoh Aficio Sp 4310N Monochrome Laser...
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Savin copier c2410 error code 421?
http://www.restoreguard.com/p/error-421.html?keyword=Error%20code%20421&gclid=CNTmo4vZ26UCFYtspAod1CIj0w
very common fault with win 7 click the above link and it will install the corrupt / missing program files
Dec 08, 2010 | Savin Office Equipment & Supplies
Savin error code E-547 error code?
Fusing unit trouble.Clean the thermofuse and thermistors,check the heater lamp.After ,enter in the service mode turn the power switch OFF unplugged the crd.Wait 10 sec. plugg the cords and turn ON the machine.I think the Savin is based the Ricoh copiers machine.The service enter code is : Press the toral clear key - 1 - 0 - 7 -hold down the C key more 3 sec.
Aug 17, 2009 | Savin Office Equipment & Supplies
hi fixya180,
Kind regards
Mar 07, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
