Question about Vizio E320VA 32 in. LCD HDTV
Need to find set up signal on vizio E320VA for new atenna to work
I can't find the screen to set up signal for my new Leaf indoor antenna. The input source is TV/DVD
    Sergeant:
  • 290 Answers
It's probably "setup" then "channels" then "auto scan".
Posted on Jan 01, 2014
Seritath
  • 86 Answers
SOURCE: how to recieve over the air channels on my vizio
No.You might not have a reliable service provider or you might just be in a area in which t.v. signals are hard and or impossilbe to recive.You might also have the cable box,or just cables,mixed up.Hope it helped.
Posted on Oct 08, 2009
SOURCE: Vizio PIP second input source
Can you use a splitter somehow to make the cable be two inputs? That is all I can think of.
Posted on Feb 14, 2009
budmrtn
  • 11361 Answers
SOURCE: vizio 320m. I set it up wrong. Instead of choosing
You should be able to use the input/source function on your remote to select which signal sources you want the TV to display, find out which input on the TV you have the cable box hook it up to then just select that input. Do you still have the user manual?
Posted on Oct 31, 2009
budmrtn
  • 11361 Answers
SOURCE: Vizio GV42L 42 in. will not receive digital
You have to make sure it is set to 'AIR' not 'CABLE' when choosing scanning setup.
Posted on Nov 06, 2009
BoiseLCD
  • 63 Answers
SOURCE: 42 in. vizio. just went blank. no sound or pic.
unplug it from the wall and hold down the power button for a few seconds to discharge any residual energy left inside the TV's electronics. Then plug it back in and see if there is any picture, even if only for a moment.
Some sets will have a reset sequence that restores all the factory defaults. This will sometimes bring your TV back around if it happens to get stuck on stupid. You'll have to search Google for your model's reset button sequence. Often it will be something like: With the power off, hold down the INPUT and VOL+ buttons at the same time. Click the power button and continue holding down the INPUT and VOL+ for a few seconds.
Your's may be different, or not at all.
I've seen this fix a TV before. But I've also seen this symptom on a TV that had a bad logic main board. Another thing to try would be a firmware update. See if your TV has a USB port available to do this. It will often be labeled as "SERVICE". Again, you'll need to search the web for more instructions, and for the firmware file itself. Often these can be obtained from the manufacturer's web site.
Posted on Nov 26, 2009
After installing an outside antenna, our unit will not get streaming media.
Roku 101: everything you need to know about your Roku ...
https://blog.roku.com/.../roku-101-everything-you-need-to-kn...
Roku, Inc.Dec 22, 2011 - You will find in-depth posts on new channels, features and updates, and ... to stream your personal media from a laptop, desktop or media server. .... Alsomake sure your phone is connected to your home WiFi signal and not an outside one. .... The Sony unit seemed possible, but after watching the video I ...
Mohu Sky 60 Amplified Attic/Outdoor HDTV Antenna with ...
www.amazon.com/...Outdoor-Antenna/.../B00AVWK...
Amazon.com, Inc.Next step was to now get working on the install of the antenna, outside. ... Sat. that was outside, coax cable already run, and this Dish was not in use. ... I have MANY more pictures, it appears that Amazon will only allow up to 5? ... Three months after my initial purchase last year, the attic mounted MOHU Sky went dead. Well ...
Mohu Leaf 50 Amplified Indoor HDTV Antenna - Made in ...
Dec 21, 2015 | Televison & Video
Blue screen
This sounds like a signal issue. make sure your antenna is connected. Try a different input device. connect a dvd player, set top box for satellite or cable, or a camera, set the tv to the appropriate input and check for an image. Hope this helps.
Apr 28, 2014 | Vizio GV42L 42 in. LCD Television
Problem with HDTV POWERED FUTURA ANTENNA 24769. Amp light goes out when connecting cable to amp. No difference in picture quality or quantity.
Well I think you are trying get a better picture not a better stereo signal unless TV tuner is in AMP. If not try connecting it to TV dirctly but first inquire manual to make sure that is how it is sappose to be connected. But if I was a betting man thats probley what it is, but not sure what equipment your working with besides the info on atenna that you sent.. Good Luck !
Apr 15, 2014 | GE 24769 Futura HDTV Indoor/Outdoor...
How do I set TV to antenna - Vizio VA26L
The input should be selected as 'TV' to get any on-air transmission. Now the input is selected to Cable. Change it to TV. Refer its user manual for more details.
Aug 04, 2012 | Vizio VA26L 26 in. LCD HDTV
No signal on dtv built in can receive anologue
You might need a new indoor atenna. Check Argos for a cheap antenna and plug it in.
If you can not receive any Freeview digital channels you will need to subscribe to Sky or Virgin
Jan 23, 2010 | Televison & Video
Vizio SV470m with a pixelated screen after being on for 5 minutes
verify if it only happens on the antenna/cable input and if it works fine with dvd or other input, then it is a signal issue with the cable or antenna u r using and repair that problem and not the tv
Sep 24, 2009 | Vizio SV470XVT 47 in. LCD TV
No antenna signal nor found channels for my area.
You'll need a better antenna to solve your problem. With the new digital broadcasting, signal strength is everything. With analog, a weak signal would give you a watchable but fuzzy picture. A weak signal with digital gives you nothing, or possibly a picture that freezes up or breaks into blocks (pixellation). The only cure is a better antenna, either an amplified indoor antenna or something outside.
Sad to say, there's no guarantee that will work. If you live too far from the station, or have hills, buildings or other obstructions that block the signal, you just may not be able to pick up some channels. In some areas people have found they get no reception at all.
At www.antennaweb.org there's a tool that will tell you what stations are around your area and how far. It's designed to help you figure out what kind of antenna you might need.
Jun 15, 2009 | Insignia IS-PDVD10 Portable DVD Player
Same problem
Then I would say you have a problem with the Main Board in the 37". Have it looked at by a service company in your area if he wants to work on a Vizio. Parts are difficult to obtain at times.
Jun 08, 2009 | Vizio L37 Television
I can't get a TV signal on new 22" VIZIO
If you are getting the "No Signal" message you need to connect an antenna or cable to the antenna input. You also need to go into the menu for your signal source and select ANTENNA or AIR if you are using an antenna OR CABLE if you are using cable.
NEXT YOU WILL HAVE TO SCAN IN YOUR STATIONS !! This is not like the old analog sets that plug in and run.
The instruction manual will give you precise instructions.
Feb 19, 2009 | Vizio L32 32 in. LCD HDTV
Vizio E320VA 32 in. LCD HDTV Logo
102 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
