Question about Parrot Bluetooth Kit Mk6100 With Oled Display
Mki9100 remote will fit in mk6100? - Parrot Bluetooth Kit Mk6100 With Oled Display
Mki 9100 parrot to fit in my 03 plate merc clk. do i need an extra cable?
They advise using a professional installer. And I found this
http://dbinstall.parrot.com/compatibility_pdf.php?model=1031&ck=12
For the CLK there is a special kit
http://www.ebay.com/itm/MKI9100-CT10MC02-Mercedes-CLK-Class-Parrot-Bluetooth-Handsfree-Car-Kit-/141233049285
and mentions a lead
Kit Consists of the following:
  • MKI9100 Parrot Bluetooth Handsfree
  • CT10MC02 Parrot Wiring Harness Adaptor Lead
Parrot MKi9100 https://parrotcontact.parrot.com/.../MKi9100_User-guide_UK.pdf ยท PDF file Parrot MKi9100 - 4User guide Installation WARNING: We advise our customers to have the Parrot MKi9100 fitted by a professional. Before you begin
Dec 30, 2015 | Cars & Trucks
My nokia 220 wont pair with my parrot mki910 any ideas?
must sync blu tooth devices. see if it recognizes device, both must be on. and do it when you are not driving. at start up, before you drive. Thanks! safety first!! the radio might have an ID that must be entered into phone.
Feb 11, 2015 | Parrot MKI9100 Bluetooth Car Kit with...
Parrot troubleshooting
www.parrot.com/usa/support/parrot-mki9100
Aug 10, 2014 | Parrot MKi-9100
How do i clear paired devices ?
go into settings then paired devices and then you can delete any paired phones
Jun 17, 2014 | Parrot Mki9100 Car Handsfree Kit
Parrot mki9100 keeps turning off during calls and resetting
Is this a problem when utilizing power on via the patch cord (power adapter) or when separated and powered by internal battery? If when attached to adapter, you may try another power adapter to see if this happens with the alternative unit. If so; the internal power supply may be defective or a short on the circuit board may occur.
Jan 26, 2014 | Cell Phones
Had mki9100 fitted in vauxhall vivario overnite looses radio memory and has now flattened itouch so much that it wont recharge
check the battery lead it should not showing 12volts. and may be is a fuse. this lead is to keep the memory in the car stereo. But I'm not talking about the 12 volts from accessories, because this lead should be good that is why the radio is turning On.
Jan 03, 2010 | Car Audio & Video
IPhone and MK6100
OKAY...
first i want to know how do you want your iphone to be connected on your MK1600, is it (wired or via bluetooth.)
let me know... i'm here to assist you...
regards,
micro
Jul 10, 2008 | Audio Players & Recorders
Parrot Bluetooth Kit Mk6100 With Oled Display Logo
Top Parrot Audio Players & Recorders Experts
David Payne
David Payne
yobo007
yobo007
Are you a Parrot Audio Player and Recorder Expert? Answer questions, earn points and help others
