Question about ASUS VW193T Monitor
Monitor screen gone green!
Hi
Last night the screen of my AsusVW193T turned green - one moment normal blue then suddenly green. Has been fine since I bought it 12 months back. Have I touched something I shouldn't have?
Still have red.
Hope you can help
    President:
  • 2,923 Answers
You may need to isolate the problem. Please follow the steps below:
1. Check the physical connection. Make sure that the cable is properly seated to the video port of the computer.
2. Try using different cable if it's detachable.
3. Perform a factory reset. There are some control functions, one of which is a "factory reset" which resets all the settings back to the original ...try the various menu options until you find it then press "select".
If same problem occurs after performing some steps, you need to repair to a TV tech or to the manufacturer for repair. There could be a defective component that needs to be changed.
Have a great day!
Posted on May 20, 2009
I have a Toshiba Tecra-M2-S410 machine, and it does not turn on anymore. When I remove the battery and plug it in, the power light turns green as expected. When I press the power button, two other lights...
Hi mohammad - seems the LCD of the laptop is gone bad . as u said u gets the light on the laptop and also sound and then it goes dark - shows possibly the LCD gone bad .
Give a try with this if you have a computer in your home - on the back of the monitor you will find a VGA cable (probably with a blue color end which goes to cpu ) unplug it from cpu and plug it in the laptop (side of laptop you will find a same input VGA slot blue color ) and boot your laptop after turning on both (monitor and laptop) if you find the screen on the monitor then it will be sure that your laptop LCD has gone bad .
On your laptop if you are not able to find the boot screen also that refers to LCD brokerage -anyway try the above you will be sure ..
Oct 01, 2010 | Toshiba Tecra M2-S410 (032017233812) PC...
My E771 monitor colors suddenly shifted with
Possibilities:
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
MY DELL 1525 TURNS ON AND THE NORMAL BLUE SCREEN APPEARS. THEN ALL OF THE SUDDEN IT GOES BRIGHT GREEN, THEN BRIGHT YELLOW, AND STAYS BRIGHT YELLOW
Please connect your laptop to an external monitor and see if the output is the same. If it displays fine on the monitor, then we are looking at either a screen cable problem or a screen problem. If the display is the same as on the laptop, then it is a problem with the display adapter on the mother board.
All the best.
Jan 14, 2010 | Dell Inspiron 1525 Notebook
Was watching a movie on my computer last night and all the sudden the screen started turning off and on with no picture when it was on. Has the monitor gone bad or is it a video card issue?
The simple way to check if this is a Monitor issue or not, you can unplug the monitor from the Computer and connect it only to the power outlet. If it gives you a "No signal" screen or goes through any sort of other Self test, Your monitor is fine. You can also check if the power led is blinking Amber or Green. A blinking Amber LED while the monitor is only connected to the Wall outlet indicates the monitor is faulty.
Thank you for using Fixya
Oct 08, 2009 | Dell E173FP 17" LCD Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Gateway FPD1760 the red in the rgb is suddenly gone
Your graphics card is not working propertly buy a new one.
Mar 15, 2009 | Gateway FPD1760 17" LCD Monitor
Olivia multi-media TV/monitor
Not really. Repairs are right about $150 - $250. Resistor Kit, Caps., maybe other parts, and labor charges.
Jun 27, 2007 | Olevia MN-20LCDTV-SN 20 in. EDTV-Ready...
LCD monitor screen blue
Either the VGA card or the monitor can not display the resolution correctly, so you need to get it back to where it was, this solution is for Windows users (not sure about other OSs), reboot your system and and get in the options start-up screen by pressing F8 at boot, choose safe-mode with VGA, if you see your desktop normally here then it's definately the screen resolution, set it back to a lower resolution (try 1024X768 and go downwards until it works fine), restart your system normally and you should be able to test new resolutions again, if it won't work using VGA mode then you might need to uninstall your VGA card but make sure that you have the correct driver for it before uninstalling, also please disable any onboard graphics card if you have one. I hope this would solve your problem, please feel free to ask if you any further questions regarding this matter. Thanks
Aug 16, 2006 | ViewSonic VA712 17" LCD Monitor
ASUS VW193T Monitor Logo
91 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
