Question about ViewSonic Graphic VG2021m LCD Monitor
Frequncy problem/out of range
I hve 17inch LG lcd monitor. when i start a game like monopoly or family fued etc it shows out of range as like 57/80 khz. but i can run d game on minimize screen. what should i hv to do in fullscreen mode?
  • hazarika_kau May 20, 2009
    there is auto adjustment . i tried it but it was not helpfull
  • hazarika_kau May 21, 2009
    its look like out of range 54.3khz/80hz, futhermore d game is running on another LG monitor of same model, another cpu. i hve Ge7300le graphics card. and driver is up to date. resoulution keep at 1280x768. is it graphics prob?
    Scholar:
  • 106 Answers
Adjust your screen settings that are usually found in the front of most pc"s and on the side of most LCD monitors
Posted on May 20, 2009
  • gambit3rogue
    gambit3rogue May 20, 2009
    Another way you can go around the problem its not a solution of course but you can reduce the screen size instead of using 1074x768 you can use 1152x864
My screen shows out of range and switches off
HI
I HAVE MONITOR LG LCD W1934S And vediocard 2 giga nvedia gt520> the card and monitor was orking perfectly>>>>> then i install this game (spec ops the line) tell me out of range>>> i try to format and install the latest driver of nvedia but it still this problem...then i try another game it give me the same problem>>>
please help me >>>is the monitor have any problem>>> the refresh rate cannot set to 80 i dont know
Jul 11, 2012 | LG Flatron L1951S 19" LCD Flat Panel...
LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
I just installed hasbro classic game collection on pc i have a 19" widescreen aoc monitor and when i try to play monopoly i can not see the whole picture it is like it is long and narrow and the game will...
before you start your game, you can try to modify your screen resolution and then start the game it will fit to the new screen size.
depending on your OS (winodws)
WIN XP close all windows and place your mouse over your desktop right click and select properties. a windows will pop out with the following tabs THEMES, DESKTOP, SCREEN SAVER SETTINGS.
click on settings and you will see a computer screen(s) and it will be a place to change the SCREEN RESOLUTION (800x600) (1024x768) etc try a diffrent one from the one you are using and click apply and then OK. run the game, if it persist just try a different size.
WIN VISTA click on desktop area and sellect PERSONALIZATION, click on Display settings and change the RESOLUTION.aplly and ok.
if my advice was of any help please rate me :)
thank you
Oct 07, 2009 | AOC 22" Widescreen LCD Monitor
How to unlock LG monitor controls? whenever I try to use monitor controls for brightness settings etc it gives a message "controls locked"! please help me to resolve this.... thank you!
BODY { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } P { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } DIV { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } TD { FONT-FAMILY:Tahoma; FONT-SIZE:10pt } Try pushing the menu button and the right arrow button on the monitor together for about three seconds. The message "controls unlocked" should appear.
Please don't forget to rate this solution.
Jun 09, 2009 | LG Flatron L1715S 17" LCD Monitor
Its look like out of range 54.3khz/80hz, futhermore monopoly game is running on another LG monitor of same model, another cpu. i hve Ge7300le graphics card. and driver is up to date. resoulution keep
Try switching the monitors to see if it's the monitor or GFX card issue, if it's monitor, attempt to reset it on the menu to default settings, If it's GFX card issue, go in safe mode and uninstall the GFX driver and restart and reinnstall new drivers.
May 21, 2009 | ViewSonic Graphic VG2021m LCD Monitor
Monitor says out of range
1. Turn off the computer.
2. Turn on the computer.
3. As soon as it starts up press and tap the F8 key.
3a. If a "boot menu" appears, select hard drive, press enter, and immediately press the F8 key again.
4. The safe mode menu should appear. If it does not, start over.
5. Select "Enable VGA mode".
6. The computer will now boot to native 640 x 480 resolution. You may now use the display properties to set it back to normal, within your monitor's range of course :c)
Thanks and please take a moment to rate this solution with a thumbs up, solved problem rating...after all I did just prevent your death :c) THANKS
Mar 30, 2009 | AOpen Black 17inch LCD, 1028x1024, 16ms,...
Analog Out Of range (LG Flatron L1750T)
some games need high resolution. Monitor resolution not supporting for this game.
Powersaver mode showing when the main PCB of the monitor failed. check this link to get the service center info
http://www.lgservice.com/
Nov 21, 2007 | LG Flatron L1750S 17" LCD Monitor
Monitor no display
hi, check out the connector pins if any is damaged or bent, if not try it on a different system just to confirm that its not the display card problem, let me know??
Oct 20, 2007 | Dell E173FP 17" LCD Monitor
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
Power Saving Mode during game play only
I've got the same problem but it only occurs with one, older game.
I run a Radeon 8500.
Nov 03, 2006 | LG Flatron L1715S 17" LCD Monitor
ViewSonic Graphic VG2021m LCD Monitor Logo
255 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
