Question about Canon PIXMA MX300 All-in-One Printer
Alarm light on canon printer won't go off
I have no color ink cartridge to put into my canon printer, so it insists that I check color ink (check ink U051 COL). I don't care that there is no color cartridge in there, I just wanna scan some pictures. But it won't allow me to do that until the color ink is put in. I Don't have any. So with little time to finish a project and not being able to by colored ink till friday how can I get the printer to turn off its alram light so that I can scan some pictures...? Please help! This project is due on thursday!!
  • asem786 Nov 15, 2009
    My Cannon Mx 300 printer has alarm light on.When I print anything, it does not print and comes up with the message, check the ink cartridge or something like that.How can fix this problem
cene765
  • 787 Answers
SOURCE: canon mx318 u051
Try to press and hold the resume button for 5 seconds.If this not help you need to replace the ink cartridges.
Posted on Oct 26, 2009
SOURCE: My Canon Pixma MP220 is
try following the instructions on the screen...ie 'hold down the reset button for 5 seconds to disable the low ink warning
Posted on Sep 25, 2008
komguy
  • 2306 Answers
SOURCE: MP 170 check ink
U051 actually says that the printhead is not installed, or not installed properly. You probably need a new printhead,
Posted on Dec 03, 2009
komguy
  • 2306 Answers
SOURCE: On my canon MX 310 printer I put in new Canon
You may need a new cartridge, that error says the ink cartridge is wrong or not installed properly. If it's a refilled cartridge it won't work, if it's a new canon cartridge, they warranty for 30 days from date of purchase.
Posted on Dec 23, 2009
pineworks
  • 4041 Answers
SOURCE: Showing Check Ink U051 COL. Have removed the
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Testimonial: "Thanks for the help - solved the problem straight away."
Canon IP3300 won't print color
hi chette,
its a common problem for printer dye ink,have you try to use other cartridge? a brand new one maybe?
if you insist using the old one, try these step.
1. use vinegar to clean your cartridge head
2. put a little vinegar into the cartridge
3. try deep cleaning it.
it only work for dye ink base not else :D
ciaw.
Jul 11, 2012 | Canon PIXMA iP3300 Printer
My canon mp160 printer has the color light blinking (I checked to make sure it has ink and the cartridge is in correctly) and won't print color. Thanks for any help.
Usually the cartridge is out of ink in which case get it refilled or it may be electrically failed in which case you will need to buy another cartridge.
If putting a refilled cartridge in the machine you will normally get some kind of error code, to clear this, press and hold the resume button (Black with red circle with an arrow head pointing towards you) for about 10 seconds then release it and usually you can print. The orange light will however stay illuminated or flashing.
Sep 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I am refilling the black ink of my canon printer using continuous ink container but the black color doesn't flow into the end of the hose and it didn't print at all, please help
  • Check the printer's power/alarm light. If it is flashing orange, count the number of flashes. Look up the flash code in your printer's user manual to diagnose the problem.
  • 2 Remove and reinstall the ink cartridges if the power/alarm light flashes 5, 7 or 15 times consecutively. This indicates that the issue is a cartridge error, an incorrectly installed cartridge, or an unrecognized cartridge. These errors can be fixed by reinstalling the ink cartridges. Make sure that you are using the correct ink cartridges for your Canon printer.
  • Turn on the printer and open the front cover. The ink cartridge holder should move to the replacement position.
  • 4 Verify that the colored ink cartridge is inserted in the slot on the right and the black ink cartridge is inserted in the slot on the left. Swap the cartridges and reinstall them in the correct slots if necessary.
  • 5 Check to see that both ink cartridges are level with one other and parallel to the top of the ink cartridge holder. If either cartridge is wedged at an angle, gently apply pressure to the cartridge until it clicks into the correct position.
  • 6 Close the front cover of your Canon printer and wait while the printer initializes the newly installed cartridges. This can take a minute or two.
  • Jun 12, 2011 | Office Equipment & Supplies
    I replaced the color ink cartridge. Now there is an "E" flashing alternately with a "5". The alarm light is on steadily, and the black ink and color ink lights are flashing. How do I...
    E5 is a Cartridge cannot be recognized error.
    Reinstalling the cartridge could clear the alarm.
    If this does not work,
    Removed both ink cartridges.
    Turn off printer and unplug fron electrical outlet.
    Wait at least 5 minutes.
    This will let the printer reset itself.
    Plug printer back in and turn on.
    Printer will cycle and an E5 will appear.
    Installed back ink cartridges.
    Jan 26, 2011 | Canon PIXMA MP150 All-In-One InkJet...
    On my canon MX 310 printer I put in new Canon CL-41 Fine color cartridge and now the alarm light is lit and the screen says Check Ink U051 COL How can I correcty the problem?
    Dec 23, 2009 | Canon PIXMA MX310 All-In-One Printer
    My canon pixma 180 has orange alarm light and reads check ink cartridge,. it won't print. it printed yesterday.
    One or both print cartridges are defective.Look under the "check ink" what message come.If it's BLK change black cartridge, if it's CLR change the color cartridge.If BLK and CLR change both cartridges.
    Nov 05, 2009 | Canon PIXMA MP180 All-In-One InkJet...
    Will not print. color ink cartridge light keeps
    ..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
    Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
    Scanner won't work
    How to use the scanner with a black ink cartridge install and no color ink cartridge install, plus the alarm light is on
    Sep 13, 2009 | Canon MX300 Office All-In-One Printer
    Refill Ink Cartridges
    First check the cartridge slots for spilled or dried ink. You can clean the slots with a tiny bit of alcohol on a Qtip.
    Aug 22, 2008 | Canon PIXMA MP150 All-In-One InkJet...
    Canon PIXMA MX300 All-in-One Printer Logo
    1,381 people viewed this question
    old marine
    old marine
