Question about Whirlpool Duet GHW9150P Front Load Washer
Strainer for drain pump
I got it out and it was a mess.....i cleaned it out and is there suppossed to be a filter over the strainer part?    If so how does it go back on there?
  • crazy257 Oct 19, 2007
    Thank that was a bra pad.....he he he he...again thanks
  • 290 Answers
There is no filter that goes over the strainer. The strainer is just to catch coins and such that would lock up the pump.
Posted on Oct 19, 2007
How do I get to the pump to clean it on my Kenmore he5 washer
Remove the bottom panel in the front or toe kick area. It's 2 or 3 small screws and lifts up. You may have to tilt the machine back to remove it. The pump and strainer are accessible there. The strainer cap screws off, put a catch tray under it because up to quart of water can drain there. Clean the strainer of debris before replacing pump.
Feb 14, 2015 | Kenmore HE5t Steam 4.4 cu. ft. Front-Load...
Gas filter for Nissan Altima2006
Like many late model cars the fuel system in this car doesn't use an in line filter anymore, this has been the case since the early 2000's, so there is no part number. The only filter in the system is the fine mess nylon screen at the intake to the fuel pump inside the gas tank.
Feb 04, 2012 | 2006 Nissan Altima
How do i clean a filter of a whirlpool awm 5080 front loader
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Does a maytag model mah2400a have a drain filter i have a sour smell an have tried vinager bleech and baking soda nothing has worked any suggestions
It has a strainer. These strainers are evidently designed to make washers stink. Your strainer is located behind the kick panel, below the main panel. The strainer is located between the drum and the pump. It is connected to the drum with a rubber hose. Unplug your washer. Pull and clean the strainer, While the strainer is open, look up into the pump suction cavity and remove any loose debris that you see in there. Reassemble the strainer, replace the kick panel.
Clean the door seal face with a bleachy water solution, let it sit, and wipe it down again. You want to get the solution into the grooves behind the seal face, and wherever you think mold and mildew might be on/in/behind the bellows seal.
Put one cup of bleach directly into the washer tub.
Fill all of the dispenser cups with bleach.
Run the washer on your hottest setting (no clothes). I use the sanitary setting with an extended wash.
When the cycle is finished, run another cycle with nothing in the dispenser cups or tub, Just plain hot water, this will flush out the bleach residue. Most folks wipe their bellows seal face and grooves down with bleachy water regularly. (1X / wk).
Hope this helps. Best regards, --W/D--
Aug 10, 2009 | Maytag Washing Machines
Does not pump out water
There are two things that you can do that will help:
1. Clean your strainer. It is located between the drum and the pump, very low in the washer. If yours is a front loader, it's behind the kick panel and is located between the drum and the pump. The strainer is connected to the drum with a rubber hose. Unscrew the strainer, and clean it (caution, water!). Look up into the pump and remove any debris that has made it past the strainer.
2. Dump the contents of your drain hose (the one that goes to the wall drain) into a bucket. If possible, run an empty load with your hose pointed outside.
Aug 08, 2009 | Washing Machines
Press stop, cancel twice to reset. The Ld error is when it takes longer than 5 minutes for the washer to drain and reset the sensor. You probably have a partially plugged strainer or drain line. To check the strainer, remove the kick panel at the front bottom of the machine. The strainer is ibetween the drum and the pump, being connected to the drum with a rubber hose. Open the strainer (caution, water!), and clean. If you did not find much in the strainer, clean the drain hose. Dump the contents of the drain hose into a bucket. If possible, run an empty losd with dth drain line pointed outside.
This should fix your issue!
Best regards, --W/D-- feel free to rate this solution...thanx!
Aug 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Hello I'm an M.B. tech.. It sounds like the fuel strainer is clogged. It is a very common problem on M.B. diesel engines of that era. Diesel fuel develops algea inside the fuel tank and after a period of time it clos the strainer. The strainer is at the bottom of the fuel tank where the big fuel hose attatches to the tank. The hose unscrews frome the strainer and then the strainer unscrews from the tank. There is a filter on the strainer that can be cleaned and reinstalled. In the engine compartment there is a small primer pump that is by the fuel rack inline with the feed hose from the tank. If you turn the knob(clear or white plastic) on the pump it will retract allowing you to use it as a hand pump. If when attempting to retract hand pump it is sucked back down and will not stay retracted that means you have a restriction in the line- your fuel strainer is clogged is the most likley problem. replace both fuel filters during repair for best results. Good Luck
Apr 14, 2009 | 1988 Mercedes-Benz 190
FDW60 Dishwasher
The strainer is located directly under the lower sprayer arm. When the strainer becomes clogged with food and detergent debris, the dishwasher may flood or overfill. On some dishwashers, the strainer is a plastic or metal component consisting of two semicircular halves. To remove this type of strainer, pry it up. On other dishwashers, the strainer is a one-piece component. To remove this type, remove the cap that holds the sprayer arm on its shaft. Then remove the sprayer arm and the strainer.
Wash the strainer in the kitchen sink with water and a mild household detergent. Use a fairly stiff brush to get all the debris out of the holes and slots in the strainer. Rinse the strainer well and replace it. If part of the strainer lifts out for regular cleaning, check it and clean it -- if necessary -- after each load of dishes is washed.
Oct 13, 2008 | Hotpoint 24 in. FDW60 Free-standing...
How to Clean Pump Strainer basket
Turn the swimming pool pump off and wait for the water to drain from the strainer basket. You want to make sure that the pump is completely off before you proceed. Remove the screws or any items securing the lid of the strainer basket. Open the lid and pull out the strainer basket. Vacuum the strainer basket or scoop out any debris. You may want to run clear water through the basket to ensure you removed all debris. Feel toward the impeller and remove any clogs or obstructions preventing the impeller from working properly. Check the o-ring under the cover of the pump strainer housing. You may need to use a silicon lubricant to ensure a water-tight seal. Put the strainer basket back into the pump strainer housing and pour some water into the basket. Replace the lid and secure it in place. Turn the swimming pool pump on and check for proper pressure. If your pressure doesn't register, you may need to troubleshoot to find the problem.
Aug 27, 2008 | Belle Foret Accessories NBBS2-TB Tumbled...
Washer will not pump out water and have cleaned the strainer
Depending on the specific model of your washer, probable culprit for "No Drain" with the strainer (filter) clean are:
  • stuck/defective drain valve;
  • defective drain pump/impeller;
  • kinks in or clog drain hose.
Please visually inspect/clean (and replace if needed) the above mentioned components.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 01, 2008 | LG Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
77 people viewed this question
Dan Webster
Dan Webster
Sal De
