Question about Garmin nuvi 54LM GPS Automobile, 5" LCD
How to charge a gamin 54lm battery
How to charge battery
Why garmin nuvi 54lm does not speak out name of street in turning
Go to settings and make sure the mute button is unchecked and the volume is turned up!
Dec 09, 2014 | Garmin nuvi 54LM 5" GPS with Lifetime Map...
Gamin nuvi 1450 wonot start and the gamin express cannot recognize it
Your Nuvi has to boot past the Garmin logo to the main screen before it can be recognized by your PC. Is the unit dead? The Nuvi 14xx series is well known for its problem with the rear USB port coming loose. This will prevent the unit from receiving power from the external charger and will prevent the battery from being charged. If the unit goes into a boot-up loop, displaying the Garmin logo then shuts down, this is often caused by corrupted files, such as a map or bad firmware update. See these two links for more info:
SHARCNET USA Out of Warranty GPS Digital Camera Repair SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Nov 01, 2014 | Garmin nuvi GPS
Gamin 405 is not charging
You need a watchmaker to examine it and determine if it is not being properly charged or the capacitor is bad.
Oct 07, 2012 | Garmin Forerunner 405 Watch
Gamin 405 battery keeps going flat.
Yeah - that's a problem - you can send them back for a replacement but it's expensive.... it certainly happens - there is a definite lifetime in terms of # of charging cycles.
May 27, 2012 | Garmin Forerunner 405 Handheld GPS...
My gps gamin 660 is not charging. Do I need a new battery or it is an other fault?I have just updated/ download new map 2012.12
Check to make sure that you have a yellow lightning bolt over the battery icon on the main screen. If not, your charger is bad. If you do, then the battery is probably bad. Please see these links for more info:
http://www.sharc.net/gps_battery_repair.htm
http://www.sharc.net/gps_charger_repair.htm
- Jim
Jun 11, 2011 | Garmin Nuvi 660 GPS Receiver
My garmin 765 T won't turn on- I have charged it overnight
If you are charging your unit with the USB cable STOP - use only a wall plug. The unit will not charge using the USB cable. If you don't have the wall unit - try charging it with the car plug charger for 15 minutes. Just let the car charge it running or not. You will see it work. Once it is charge over half way - the rest will charge up. It is a problem Gamin is working on.
May 05, 2010 | Garmin nuvi 765T GPS Receiver
My mains charger exploded and now 205 does not charge also no comms. Unit worked normally till battery went flat. When plugged into PC usb, Unit gets warm in area around mem card but does not charge.Any...
This is a new set of symptoms to me, but whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Feb 11, 2010 | Garmin nuvi 205W GPS Receiver
Where can we find free garmin gps updates for free
Garmin did that in the beginning. I am really sorry they started charging for their updates because I paid for their newest and found that even it needs work. Last year I was driving in North Carolina when suddenly the Gamin showed me in the middle of a field and trying to get me to turn around. I was on a new highway that was not found or listed in the recent $80.00 update. I love Gamin but they do need to do better on their updates! The best solution is to go to garmin.com and have a chat or call them. I'm a little late for that because the street changes are much faster than a decent updated update. Their products are great and your model may qualify, but I'm not going to pay again! Sea Breeze
Jan 14, 2010 | Garmin nuvi 250W GPS Receiver
Wont turn on
Open and take out battery - after 10 mins return battery and it will switch on
Aug 08, 2008 | Garmin StreetPilot c550 GPS Receiver
Garmin nuvi 54LM GPS Automobile, 5" LCD Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
