Question about Rotel RMB-1095 Power Amplifier
Rotel power amp
My rotel power amp (1 year old) is playing through only one speaker - if the connection is moved to the other speaker it works. So its not the speakers. any suggestions?
    Sergeant:
  • 273 Answers
Some amps have a switch to bridge them rather than wiring a bridge meaning output is mono check to see if yours has this switch if you do simply put back to stereo
Posted on May 20, 2009
HALLO I HAVE A ROTEL RA 9858X AND AGTER PLAYING FOR A FEW MINUTES I LOSE THE RIGHT SPEAKER CHANEL
Try interchanging the speakers. If the right channel works, you have a problem with your speaker.
Jun 14, 2014 | Rotel Audio Players & Recorders
Power amp r b 981 no power to the speakers. Pre amp seems to be ok. Headphones work.
Check the headphone socket if it cuts out the speakers (normal use) when you plug the headphones in. If it doesn't and you have a switch to switch off the speakers when listening to headphones, check the switch. It may be physical damage or dirt causing the problem, or even loose soldering on the headphone socket. But the fact that headphones work shows the main amp is working. Also make certain the speakers are connected properly.
Sep 28, 2010 | Rotel Audio Players & Recorders
No sound to remote speakers in dining & deck areas.
Incoming from WHAT? Ampifiers accept inputs via RCA connections and send amplified audio to the speakers via the + and - OUTPUT terminals.
I'm guessing your colored wires are from your speakers and that there is a piece of this puzzle we do not see - how the speakers on the deck and in the dining area are wired.
You say, "was working ok previously"... previous to WHAT? Something changed.
You can probably troubleshoot and resolve this yourself.
Set the amp to a medium output level.
If the wires are simply leading to either or both pairs of speakers you could select any two of them and connect them to one side of the amp. Only a pair going to the same speaker(s) will produce sound. Once you identify one pair, the other pair probably goes to the other speakers. Connect them to the other channel output.
The last piece would be to establish correct phasing between the speakers. Bass response will suffer if they're not IN-phase. Play something with substantial bass. Listen closely, then reverse the wires on one side only. Test again. If it IMPROVES you have it right. If it losses bass, put the wires back the way they were.
Apr 27, 2010 | Rotel RMB-1095 Power Amplifier
I have rotel amplifiers when i connect my speakers the amplifier stop working
check the ohms on the amp output and the amount of ohms on the back of your speakers they should be the same (or at least the amp should be more) ....your speakers may be overpowering your amp
Jul 01, 2009 | InFocus 1:2 Distribution Amplifier...
Rotel Receiver RX-950 AX popped and then quit
there would be life in the old girl it just depends how much you love her and how much you are willing to spend to get her fixed ?? some old rotels are still fetching good money so it might be worthwhile getting a quote
May 26, 2009 | Rotel RX-950AX Receiver
Right speaker jack not working
Why would it die from being in storage? Oxide or corrosion on contacts, volume potentiometer, Tape Monitor or other switch contacts.
Try manipulating all controls and switches throughout their ranges many times and see what happens.
Check the heaphone jack. If it works so does the right amplifier. While you're at it, insert the headphone jack multiple times to cycle its contacts, too.
May 18, 2009 | Rotel RMB-1095 Power Amplifier
Rotel PReamp, Can I directly Connect my powered speakers to the output
Based on your post, the pre-amp is doing its job. What might be the mismatch would be the powered speaker system plugged into the output of the Rotel. Depending on what the "powered speaker system" is, it might be that it is a low impedance such as those used in computers whereas the Rotel requires high impedance to be connected to its output. What could be tried is to connect a regular amp or receiver to the Rotel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 05, 2008 | Nakamichi AV-7 Receiver
Problem with Rotel RA 870
Since it is a Rotel, it is a good unit and worth fixing. At this point, you need to take it to a good repair shop and let a qualified tech look at it. There are no user serviceable parts inside and if you go poking around in there, you WILL make the problem worse. Rotels' are nice units and represent a good value in stereo gear. Take it to a reputable repair shop that repairs Rotel under warranty. If thats not available to you, then a good repair shop should be able to get you going. Good luck...Rob
May 09, 2008 | Audio Players & Recorders
Free booklet/part #149393
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
Jan 10, 2008 | Bose 901 VI Main / Stereo Speaker
386 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
richie46
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
