Question about Filters 99-0621 : Air Filter Cleaner & Degreaser - 32 oz. Squi
What are the oil filter numbers for a fiat farmliner 445
Where is the oil filter located on a 2012 fiat 500?
They have a cartridge filter near the front of the engine on the firewall side. You spin off the top and pull the cartidge out.
Jul 15, 2017 | Fiat Cars & Trucks
Sorry, but there is not such ting as a 2006 FIAT 124. Fiat 124 was produced since 1966 until 1980 in different onfigurations such as spyder, coupe, and sedan. The oil filter on those cars is located low, at the driver`s side of the engine, just behind the time belt cover.
Nov 10, 2013 | 2006 Fiat 124
When is the first tuneup on the 2012 fiat 500
From my User Guide p. 63: 8,000 miles or 6 months - oil and filter change, rotate tires. At 16,000/1 yr more extensive inspections and filter changes.
Jun 01, 2012 | 2012 Fiat 500
Just wondering what kind of engine oil do i use on a 1973 fiat x1/9 and what kind of filter does it take? hope to hear from someone, thanks
with cars of this age i would just use a standard 20/50 engine oil.
this is slightly thicher than would have been used originally (10/40) but does make compensate for normal engine wear after 38 years.
the oil filter is common to a lot of fiat engines and is still usually available on the shelf in most motor factors. (halfords etc). the part number for the filter is different for different manufacturers but all factors will find the number easily.
the filter is also readily available on ebay, but with postage charges, can actually work out more expensive.
pick your nearest motor factor and ask them for the filter/ they will probably have it on the shelf for under £5
Apr 28, 2011 | Fiat X1/9 Cars & Trucks
58 reg 40.000 miles fiat doblo 1.3 d . oil in water , ( blocked filter some fpc filter not sure what its called not oil filter) starts but wont rev properly cuts out wont re start. fiat had it changed...
NOT SURE WHY YOU HAVE oil in the water but i would suspect head gasket but these motors do have a oil cooler i think so check this out ,now first thing after that to do is block off the EGR valve ,make a coca cola can gasket to seal it off completely ,then this particle exhaust thing remove it and fit another back box any back box you can bodge on and then see what happens ,these so called anti polution things are a waste of time on a diesel ,Would help if knew what year a 58 reg was because to me its a 1958 for all i know and A reg is a 1963 ,now that was when they made real cars like a humber hawk and wolsley .These fiats are not bad little jam jars and to me a lot better than these american things with monster engines ,wonder what they would do if they had to pay europeon fuel prices???
Apr 21, 2011 | Fiat Strada Cars & Trucks
Where is the oil filter located on a 2008 Fiat Panda 1.2 petrol engine?
IF YOU DONT SEE OIL FILTER UNDER THE ENGINE NEXT TO OIL PAN OR ON SIDE OF ENGINE LOOK ON THE UPPER SIDE OF THE INTAKE MANIFOLD LOOK FOR A FILTER LOOKING HOUSING WITH A BUILT IN LARGE BOLT HEAD ON COVER HOUSING OIL FILTER IS IN THE HOUSING.
Oct 24, 2010 | 2007 Fiat Pininfarina
What oil do i use in a fiat grande punto
fiat use 10/40 semi synthetic for Europe,with oil/filter changes at 10k/annually.
Oct 23, 2010 | Fiat 500 Cars & Trucks
How much litters oil need to change on fiat brava 1.2 16v with oil filter
My info is that it should take 2,8 litres with oil filter and it should be full synthetic oil grade 5w40. Hope that helps
Feb 03, 2010 | 2006 Fiat X1/9
Fiat brava oil warning light wont go off
<grin> I don't know why or how this ended up under the category of Fiat 2006 X1/9 - I'd like to have one but I think I will have to be satisfied with my '87 Bertone instead-
I would highly recommend you have a shop replace the sensor (very soon!) with a pressure gauge to measure the pressure directly to make certain you aren't dealing with a failed or obstructed oil pump. This will only take a few minutes and shouldn't cost much. If your engine isn't clattering, I suspect the replacement sensor isn't any good either.
Oct 24, 2009 | 2006 Fiat X1/9
Filters 99-0621 : Air Filter Cleaner & Degreaser - 32 oz. Squi Logo
41 people viewed this question
Top K&N Products Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a K&N Products Vehicle Part and Accessory Expert? Answer questions, earn points and help others
