Question about Nokia 5800 XpressMusic Smartphone
Screen goes blank during calls
Hi, phone works fine, but as soon as I press the call button the screen goes blank and the green, white and red lights die out. It also doesn't light up on incoming calls.
Appreciate some guidance. Thanks
    Scholar:
  • 106 Answers
My friend I'm sorry to inform you but thats what nokia's do it doesn't matter what kind of nokia one owns all nokia turn off this problem start as soon as they released the nokia 6103. I know this because I to own an express cell. Call tech support and maybe you'll be lucky to get a cell without the bugs I'm on my 3rd return so far so good
Posted on May 20, 2009
T mobile touch pro 2 doesn't power on.
Take the battery completely out of it and let it sit for about 5 minutes. Then install the battery and see if it will turn on normally.
Don
Apr 06, 2012 | HTC Touch Dual Slider Smartphone
Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
Mar 02, 2011 | InFocus LP 250 Multimedia Projector
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
Screen goes blank 2 seconds after powering up and then wont work
contact your service provider for a repacement phone if you have warranty or phone insurance. its and internal problem.
Apr 26, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blank display
You seem to have a issue with the Flex Ribbon Inside. The Display has a Flex ribbon that connects to the keypad area. there seems to be a fault with that ribbon. this is common problem with **** shell phones/ Slider phones.. best solution would be to take it to a repair shop. unless you have warranty.
Mar 24, 2009 | Motorola Mobility RAZR2 V8 Cellular Phone
Blackberry Pearl 8100c Screen blank out
i want to change the network code of blackberry peral 8100
how i can unloack the phone
IMEI = 355767018968151
Dec 22, 2008 | RIM BlackBerry Pearl 8100
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
HTC Tytn 11 I got it wet. It was dried out and worked but now the screen is striped red green blue and white with KAIS130 MGF SPL-1.0. OliPof CPLD-8 on the red stripe and Serial at the bottom on the white...
I will assume you bought it on Ebay or the Internet somewhere from the text you say is on the screen.
There is a possibility you have lost the information on the phone and will need to reinstall anything you have added to it since you bought it, but possibly not.
First thing to try is what is called a "Soft Reset". If you have not already done so, take your stylus and press it lightly into the small hole in the bottom of your phone until you feel a light click. Your phone will restart. If it boots up normally, then you are done, and everything is roses again, and your information should be in tact. Yea!
If not, then you would next try a Hard Reset. This step erases any information you might have added to the phone since getting it and puts it back to the factory defaults. There are two buttons below the screen that when working normally say "Calendar" on the left, and "Contacts" on the right. You need to hold both of these buttons down then insert your stylus into the reset hole at the bottom of your phone. You should get a screen saying "Press SEND to restore Factory default. press END to quit." Go ahead and press the Green Send key. Wait for the phone to reboot. Hopefully at this point your phone will be at the initial setup screen. If it is, follow the directions on the screen to finish the setup.
I realize this is not your phone, but the button locations are the same, and the screen should be similar.
Soft Buttons just above Send and End, and Reset Button :
Reset Screen:
I hope one of these work for you. If not, don't panic yet. There are still other options... Let me know how it turns out.
Aug 25, 2008 | HTC TyTN Smartphone
Wont turn on
.........same problem.....
only my new hard disk worked...
Aug 06, 2008 | Sony Playstation 3 (PS3) Console
Nokia 5800 XpressMusic Smartphone Logo
192 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
