Question about Whirlpool Washing Machines
3LCHW9100WQ0 WHIRLPOOL SEMI PRO
F26 out of order on machine. Not sure which one is pause button as does not state
4 Suggested Answers
SOURCE: whirlpool wm 1000 semi pro washing machine
if you can give a more complete mod # i can help you on the front loaders its a slow drain time the mod # you gave me dont come up look on the lid or the back of the control panel for ser plate http://www.whirlpool.com/custserv/index.jsp try here for manual
Posted on Dec 28, 2007
  • 16 Answers
SOURCE: F26 Error - Door Switch?
when you hear clicked can you open the door?its should be locked...
Posted on Oct 13, 2008
caroldon
  • 17130 Answers
SOURCE: Whirlpool 3LCHW9100WQ Semi-Professional 9kg Washing Machine
Possible fault with the door switch or the control panel but you can try to open and close the door few times to reset after removing power.
click this link: error code F26
Posted on Oct 03, 2013
Codes f26 and then f27 for maytag model MFH 0710
F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start. unsure of f27
Dec 23, 2016 | Maytag Washing Machines
Screen is saying out of order f26
Front bottom panel ( under ) door is removed to expose pump clean out access points lint , loose change, tooth picks Exeter. Also attached ither to top, front bottom or rear access pannel is a electrical schematic with decoder and test guide.... please do not attempt with out tools and electro mechanical experience .especially if under warranty . Ie call for service if in over your head...
Nov 05, 2014 | Whirlpool 3LCHW9100WQ SEMI-PRO FRONT LOAD...
My Whirlpool semi pro washer was displaying a F26 error code. So, I attempted to clear it by opening and closing the door, as the manual instructs. Since that didn't work, I entered the service access...
Hi, What is the model number of the unit your working on? If you can get into service mode, are you able to factory reset the unit? Most of the time this would correct any miss entered and changed programs. I need more information to direct you correctly. Looking forward in assisting you if you still need it.
Jul 03, 2014 | Washing Machines
Oct 03, 2013 | Washing Machines
My maytag commercial washer display a code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
NOTE: If the error remains on the display, and the condition above has been checked, call for service.
Oct 23, 2012 | Washing Machines
Error code F26
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Fault code f26
Jul 30, 2011 | Maytag Washing Machines
Washer says f26 and won`t spin the clothes out. is there anything i can do?
If opening and closing the door does not remove the error display, press Pause/Cancel twice.
The above procedure is the specified way by whirlpool technicians to clear the error code.
Feb 02, 2011 | Washing Machines
F 26 Code that won't go away
The F26 error code on the Duet washer is a door switch error. The button inside the door opening might be stuck so that it doesn't register as being opened and closed. First press the pause/cancel button to clear the error display. Next push the button inside the door opening a few times and pull it so that it pops out completely. That should solve the problem.
Dec 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
73 people viewed this question
Dan Webster
Dan Webster
Sal De
