Question about Akai LCT3201TD 32 in. LCD Television
How do you get a input on a Akai - Akai LCT3201TD 32 in. LCD Television
I have an akai pdp4298ed plasma tv the DVI and PC inputs are not working.
The Akai is Samsung brand--have you when using that input that does not work gone into the menu and "selected" it and or highlighted it?
Apr 14, 2012 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
I need to know what input & output connections are available on the Akai PDP4290 Plasma TV?
This was the cheapest Akai in its day. No Tuner, No Speakers, must use a surround sound or regular stereo amp for sound.
It also has the standard A/V input also.
Best to use a HD Box and RGB cables for best picture.
Dec 04, 2010 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Input cable piece broke off akai pt5499hd
The coaxial input can be soldered back in. You will need a new one however. Sometimes the internals in the tuner (where coaxial goes) may be damaged when coaxial connection breaks out. If that is the case a tech may charge more money. But just to replace the connection should be relatively inexpensive.
Apr 23, 2009 | Televison & Video
Akai LCT3285TA-need stand-remotes and 1 component input dont work
Check it out, is that remote you need for your Akai TV?
HERE is another remote but I'm not sure.
Dec 18, 2008 | Akai LCT3285TA 32 in. LCD Television
MY BLACK COLORS ARE RED
steenson
To be honest with you. Do not waste your time change the main input board, your problem is solved. Because the main input board coul be defective. I can help you get the input board. Please, my e-mail Stevebuy31@hotmail.com
Dec 10, 2008 | Akai PDP4225M 42 in. Plasma Television
Cant afford cable box need help
depending on if the dvd player has functions such as video input , but not likely
if the plasma only has certain video inputs and not the cable input you could use the vcr to get the signal
Oct 09, 2008 | Akai PDP4225M 42 in. Plasma Television
Am not able to identify the TV's video input channel for my AKAI CFT 2791
yellow input for video
red and white correspond to audio
Dec 06, 2007 | Akai CF2791 27" TV
No picture or sound
Add av input or change input settings
Oct 24, 2007 | Akai PDP4225M 42 in. Plasma Television
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Akai LCT3201TD 32 in. LCD Television Logo
16 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
