Question about JVC KD-R740BT
Installing a jvc KD-R740BT into a 2003 dodge ram quad with a xfinity system and steering wheel radio controls what are the wiring harness needed for this install to be sure everything is working corre
I want to make sure that this radio works as the factory one did with the steering radio controls and the amp that is supposed to to be installed in the truck.
    Top Expert:
  • JVC Master
  • 34,763 Answers
Installation will be easier if you purchase an adapter that will correctly match your JVC unit to the Dodge wiring.
Posted on Jan 01, 2014
SOURCE: Install JVC Car stereo
no power
Posted on Jul 27, 2008
SOURCE: JVC Wire Harness
i need to match up color wire to my 1998 honda accord
Posted on Oct 22, 2008
josetejas
  • 300 Answers
SOURCE: Just installed jvc kd-s16 and it loses power after
Connect Yellow to Battery (always 12V), red to ignition, and black to ground. Disconnect all others. Check it. If the radio stays on and plays CD, then radio is good. You may check other wiring
Posted on Jan 19, 2010
kenw392
  • 2226 Answers
SOURCE: I just installed a new jvc kd-r210 deck in my 1996
are you sure you have an antenna connected to the radio?????????
Posted on Jun 14, 2010
SOURCE: Installing CD Player in Peugeot 206
Hi dont know if anyone reads this still. First the finger tip control you have to rewire it into the new cd player with a Autoleads PC99-X26 - Peugeot 206 plus connection to your make of radio. Also the wireing problem some times is down to the red and yellow wires being the wrong way round swap them over and this should solve this.
Posted on Jul 02, 2010
Installing JVC KD-R740BT in 1997 Ford truck, keep getting "miswiring, check wires and reset" message
Check speaker wires. All four speakers must be independent. Means no shorting to chassis.
Sep 25, 2013 | JVC KD-HDR1 CD Player
Steering wheel controls
JVC radio doesn't work directly with car's steering wheel control. You need an adapter. Metraonlie.com offers pretty reliable ones.
Aug 25, 2013 | JVC KD-G230 CD Player
Can I "PLEASE" get a wiring diaphragm?
Do you still have the factory harness hanging out of the dash?? Do you just need to know what the wires are on the stereo??? If your factory harness is still there go buy you a factory install kit for your make and model of car. if you need to know what wires are what on your radio let me know
Mar 07, 2012 | JVC KD-S26
JVC headunit oranges with white stripe (illumination wire).
As far as I know, If the illumination wire is connected, the radio dims the display when headlight is turned on.
Feb 20, 2012 | JVC Car Audio & Video
How do you install a JVC KD-R300 radio into a 2003 Mitsubishi Galant? I got some kit when i bought the radio to make it where the radio would be able to hook up to the car but it says to plug this black...
if your got a wiring harness you should be able to hook your ground up with a pre existing wire from the new harness it should be black if not and your looking for a place to ground it just below your steering colum is always a good place to ground anything right on the metal itself good luck
Mar 04, 2010 | JVC KDR-300
2003 dodge ram 1500 quad cab radio take out
piece of fence wire bent in a U shape and push into the two holes either side of the radio fascia
Oct 24, 2009 | 2006 Dodge Ram 1500
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
Jvc car audio KD-PDR51installation problem
Your switched ignition lead is hooked to a constant voltage wire.
You need to find a source wire that is only given power with the key in the on position.
One wire (yellow) on radio goes to a power wire with +12V constant power (regardless of key position)
The other wire (RED) on radio will need to be attached to a Power wire whose supply is only +12V when the ignition is enabled.
Since you are using a wire harness, you just need to reverse the 2 wires as they currently are installed.
Hope this solves one problem anyway.
the wires being reversed on the harness also may not activate an internal relay allowing the steering wheel functions to operate.Switch the 2 power wires, and re-try.
If the steering wheel controls still fail to operate properly, your module may be defective.
Post your results.
Jan 15, 2009 | Car Audio & Video
Installing kenwood kdc-mp238 in a 2001 dodge ram 2500 quad cab
No ur radio is fine to fit the wiring harness into ur dodge the wiring has been crossed so it wont work, if u go 2 the Kenwood US site and down load the KDC MP 228 manual it has a good wiring dirgram and with a bit of work u can work out what goes where :0 Hope this helps
Oct 11, 2008 | Kenwood KDC-MP228 CD Player
JVC KD-R740BT Logo
90 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
