Question about Imperial IR-4-G12 Elite Gas Kitchen Range
How to light vulcan flat griddle - Imperial IR-4-G12 Elite Gas Kitchen Range
How do I remove 24" griddle to change heat coils
Several people to lift up and one to put something underneath to prop griddle up
Oct 11, 2014 | Vulcan Hart EV60-SS-10FP-208 - 60-in Range...
Where is the pilot light
location of pilots on oven griddle and stove top
Dec 17, 2012 | Vulcan G36L Gas Range
We purchased a used Vulcan Steamer model # VSX10GC which was set up for propane. We need to convert it to Natural Gas. How do we do this and how do we get the parts
Please be careful when converting appliances form natural gas to propane. Depending on the equipment there are several changes that need to be made. You will at least have to change burner orifices and convert or replace the gas valve. Some gas valves are not convertible. What many people over look are changing the pilot orifice and on some appliances like braising pans, griddles and char broilers there is a runner tube orifice. The gas valve also needs to be adjusted to the proper manifold pressure and pilot adjustments will be required. I recommend on Vulcan equipment that you contact Hobart Service since they are factory trained on all Vulcan cooking equipment.
Mike
Mar 11, 2011 | Vulcan Hart VSX5G Counter Convection...
We are cranking up this BRAND NEW Vulcan flat top. Weh have the convection oven below up and running, but we can't even see a pilot light for the flat top. Advice anyone? Culinary-yours Chef Geir
older ovens have pilots but the newer machines are electronic ignition,there are ignitors in the oven and electrodes or ignitors on the top burners,when you turn the knob for the burner you should hear a clicking sound and see a spark around the burner,that's what lites the burner,the gas comes in and the spark ignites it,i don't know much about your machine but it can't be any different from other stoves.if none are sparking there should be a spark module in there or they could have separate modules,if you send the full model number i can look it up for you
Oct 30, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
I have an old Vulcan 6 burner commercial gas stove with a 24" griddle. The gas was turned off during a remodel. Now the gas is back on and the gas burners work fine but I cannot get the oven pilot light to...
Hi- This should have a gas Safety Valve, this is the main valve to the oven (this probably has 2). If you remove the lower panel under the doors they are probably right there. Looks like a large gas valve with a button on it, sometimes the button is red. You need to hold in that button while lighting the pilot and keep holding it in for a few seconds until the thermocouple gets hot enough to tell the valve to keep the pilot on. You'll have to do this for both ovens if there are 2 valves. It's possible the valves are located somewhere else on the range so you may have to hunt a bit. If the pilots still won't stay lit you may need new thermocouples in which case I'd call a Tech out to look at it. Hope this helps. Good Luck.
Sep 24, 2010 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
How do you light the pilot for the flat top section of our Imperial 6 top stove?
This range has a standing pilot light for the top burners and griddle top. If you look through the small hole under the flat top griddle you can see a small line about 1/4 inch that runs from the main gas manifold to the pilot light about 6 inches back under the griddle top. You will need a tightly wrapped piece of paper or a long match or small wooden stick, like a chop stick. Light the end of your paper, or stick and put it through the hole all the way to the pilot light. It should catch on fire. Whenever the main gas line is on, the gas will flow through the pilot light. If it will not light, there is a pilot light adjustment that is a very small screw in the middle of a 1/2 inch square metal fitting that is screwed into the gas manifold. If the pilot won't light, this screw may be turned all the way in, thus cutting the gas off to the pilot light. If necessary take a very small flat blade screw driver and turn the screw counterclockwise a half turn. That will increase the gas flow to the pilot light. Another way to light the pilot is to put your burning stick or match into the hole near the burner under the griddle plate, then slowly turn the heat valve to the on position. The main burner will light and then the pilot will light off of it. Don't get your face too close to the griddle when you light it, gas can flash back into your face.
Sep 23, 2010 | Imperial IR-4-G12 Elite Gas Kitchen Range
Cleaning a grill
Vulcan has an online site that allows you to down load the operation manual for just about every model... here' s link... their op manual looks pretty helpful!
Vulcan site
May 24, 2009 | Stoves 60" VULCAN RANGES GAS(CLICK HERE):...
Imperial IR-4-G12 Elite Gas Kitchen Range Logo
20 people viewed this question
Top Imperial Kitchen Ranges Experts
Dan Webster
Dan Webster
Thomas Perkins
Thomas Perkins
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
