Question about Panasonic Drills
Panasonic EY6409 12V 3.5Ah NiMH-Akku - Panasonic Drills
Er 398 beardtrimmer
take off the blade, loosen two philips screws, wide blade slowly remove the upper from the lower half.....replace old with new batteries
http://www.akku-wechsel.de/shop/akkus/rasierer/akku-fur-panasonic-bart-haarschneider-er-398.html
Jan 05, 2014 | Panasonic Health & Beauty
Tip
All nokia secret codes part4
 Caution - starting from here the codes are "dangerous"
*#7370925538#
* # of res wallet # ... is to be deleted the code around the "wallet"! Input like normal telephone number (not in wallet code inquiry windows).
NOTE! Afterwards the "wallet" is empty, can again be put on however with new code.
*# 7780 # The "original attitudes" and telephone re-establishes is again started (an appropriate inquiry and it follow before must the sicherheitscode be entered).
NOTE! Afterwards various "attitudes" are away - among other things these:
·1 Points of entrance (Provider dependent points of entrance and attitudes)
·2 Bluetooth attitudes
·3 Favorite
·4 Allocation of the two keys (beside Navi keys) in the main menue
·5 Profiles are "neglected" (as with distribution) - still there however new bell tones, etc. are...
·6 SMS/MMS/E Mail attitudes
·7 Logos and spielstaende (allegedly) also deleted...
Programs, calendars and contacts, etc. not changed...
Also the sicherheitscode remains.
This putting back goes also via menu under "attitudes - general - original telephone once.".
*# 7370 # Soft format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a software RESET. (however still another inquiry comes before.)
NOTE! If the Akku to 75% are loaded at least, Akku do not only accomplish during the procedure under any circumstances remove! The procedure takes some minutes (approx. 3-4), is absolutely waiting!
This is "only" a soft format... Hard format with "green, 3, *"... see below.
Green, * 3 Hard format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a RESET.
Proceeding: Equipment switch off, which keep "green key" (take off) at the same time pressed, "*" and to "3" key and switch the equipment on (the keys thereby keep further pressed)... to "Formatting" on the display appears...
If that does not function, then equipment for 1 hour switch off, Akku so for a long time rausnehmen and again try.
"only" virtual the memory is generally cleared - genuine formatting can take place only in a Nokia service center, if the Fash is deleted there and/or new L.G. is installed.
on May 12, 2010 | Cell Phones
Tip
All nokia secret codes part3
*#7370925538#
·3 Favorite
Sehr geehrte Damen und Herrn, ich habe mir einiger zeit eine Che-ez 2.1 Megalpixel Camera gekauft aber ledier ist der dazu gehörige Akku **** geworden und somit nicht mehr...
Sehr geehrte Damen und ich spreche nicht Deutsch, aber Google Language Tool ?bersetzung hat mir geholfen. Die Kamera braucht eine Batterie vom Typ AAA in den meisten elektrischen Gesch?fte gefunden werden. Der Blitz braucht eine CR-2 Knopfbatterie h?ufig in Computer speichert.
Dec 16, 2010 | CHE-EZ D'zign Digital Camera
How are u suppose to charge the vtech camera
I just read the "User's Manual". It recommends using 4 standard Alkaline AA size batteries. These are not re-chargeable. You can use Ni-Cad rechargeables, but I don't recommend it. They are of slightly lower voltage and this may cause you problems with the cameras operation. I recommend reading Page 3 of the "User's Manual".
Dec 29, 2009 | Vtech Kidizoom Digital Camera
When i start my nokia 6600 then my phone hanged and general system eror appears
You should go for a hard reset.
press *#7370#
The *#7370# is the equivalent of a hard reset on any SERIES 60 mobile. It will delete all software/settings etc., and restore all applications to as they where when the phone was bought.
You can get the SYSTEM ERROR problems from corrupted/edited/deleted/incompatible files that are in use, either in the fone or on an MM/SD card fitted. To see which is at fault, simply remove the card & turn on the fone again!
I get these errors often as I make software on these things (just starting).
  • if it doesnt work your bluetooth IC ic is faulty.
  • Soft format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a software RESET. (however still another inquiry comes before.)
  • Format the cell phone using *#7370#....if ur cell is slow....change the log duration to 1 day.....u can see an instant change in the speed
  • if you felt i ve spent my time for you... a very helpful rating is appreciated....
    Aug 30, 2009 | Nokia 6600
    Akku l??d nicht.
    Setzen Sie die Batterie innen richtig und versuchen noch einmal. Rob
    Feb 21, 2009 | JVC Everio GZ-MG21 Camcorder
    6600 nokia
    if this always happens.. try resetting your phone by typing *#7370# it will reformat your phone to its orig settings. warning... all your saved data will be lost like messages, pictures, videos, etc...
    this way will refresh your phone to its original settings...l
    Oct 16, 2007 | Nokia 6600
    Drills Logo
    60 people viewed this question
    Top Panasonic Drills Experts
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Richard Warren
    Richard Warren
    Are you a Panasonic Drill Expert? Answer questions, earn points and help others
