Electrolux wascator w355h
Code E45
3 Suggested Answers
SOURCE: i have a electrolux w 160, i need electric diagram
Give me your email address and I can send you the full service manual.
paul@commerciallaundrysolutions.com
Posted on Mar 28, 2011
tbirdfan1
  • 3051 Answers
SOURCE: Electrolux W355H Shows the error
Hello there and thank you for choosing fixya
This is a drainage problem meaning that you drain pump and you drain lines may be clogged so you are going to have to get first you will need to unplug the machine .
Next check to see if there is a axcess to the drain pump by removing the lower kick panel if yours has this feature then look to see if you can see the pump some of these pumps have a round plug in the top of them to allow you to clean them out if your s does clear any debris that may be in there and replace the plug ensuring that it is tight then plug in the machine and start and it should now work.
However If yours does not work still than you have a problem with the pump itself and will needd to be removed and opened up to see if the impeller inside of it is bad ok?
Hpe this is very helpful for you
Best regards Mike
Posted on May 09, 2011
How to do with E40 code of Electrolux EWF 1074?
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Aug 24, 2015 | Electrolux Washing Machines
How can I fix the error code 019 E on my Eloctrolux washing mashine W355H
You probably need a new board, but why not call the local parts supplier and tell the guy you're getting an 019 and he should be able to get you started. Just every now and then you may get around, but more than likely your will need to replace the board.
Mar 24, 2015 | Electrolux Washing Machines
Error code e45
E45 error code is a main display (control) board communication error. Only way to repair, is to replace the main control board.
Nov 10, 2013 | Electrolux Washing Machines
We have an electrolux Wascator T3530 . It is showing a fault F1 on the display. What does this mean?
First thing you can try is to unplug the dryer for fifteen minutes or so. If that still bring up the error code then it is your board inside your dryer.
May 03, 2011 | Electrolux Dryers
Error description
Go to www.frigidaire.com/support/manuals.asp
Apr 17, 2009 | Washing Machines
Model number w355h showing 03e error code at start of cycle.
have you looking in your manual, sometimes it tells you how to solve the problem, with certain codes, good luck.......
Sep 11, 2008 | Electrolux Washing Machines
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
