Question about Car Audio & Video
I want to install my car tape at home.plaease guide me through this
I have a car tape at home.i have brought a new one for my car.but the old one works in a proper way.i don't understand which wires power the car tape.i want to use it at home.will you please guide me through this?
4 Suggested Answers
  • 75 Answers
SOURCE: Please help me
When you say 'It keeps saying that the camera is marked for deletion.', where are you getting this message from? Check device manager to see if you can remove the device successfully.
Do you have admin priveleges to install on your work system? If not, the device drivers may not be properly installed.If you have XP at work, uninstall the Kodak software, then try connecting the device. You can see the camera as a mounted volume through the system drivers.
You can install just the EasyShare software, not requiring the camera drivers, if you choose to, and the camera will still mount successfully.
Posted on Jun 05, 2008
dunnbiker
  • 8546 Answers
SOURCE: Don't have a manual and
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-RCD-W500C-manual/id/423ag417/t/2/
Posted on May 28, 2011
upbeatjunk
  • 231 Answers
SOURCE: My Xbox 360 has been
More than likely this is a hardware issue with the Xbox and will need to be repaired. You can call Microsoft at 1800myxbox. There is something you do to try and work around the problem and fix it but it's not recommended. You can find the details here:
http://www.wikixbox360.com/thread/1328129/Xbox+360+Only+sound+no+picture+Help+me!
I can tell you that I did this when my Xbox no longer had video and it did work for me for a while but I still ended up sending it in in the end.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Posted on Jul 10, 2011
I brought a Digital Video Camera Model No is GR-D2700 Serial no is 060T6965. I brought this camera about 3 yrs ago and I have alway had problems getting it to take tapes It comes up error or not reading...
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Dec 16, 2010 | JVC GR-D270 Mini DV Digital Camcorder
How to replace power window motor
You'll need to remove the door panel and as the motor is riveted in you'll need a drill ... The window in the opposition with the use of duct tape tape it up so that it will not fall on you. Disconnect the power source to the motor itself and drill out the three rivets that hold it in place. Be sure to observe the way it is installed before removal as well as the guides that may be connected to it remove the old motor install the new one re-rivet the new one into place reinstall it the way the old one came out re-connect the power source and test the window by installing switch to ensure that it is working properly.
Nov 07, 2009 | 2004 Mitsubishi Endeavor
How do i change the oil pressure switch?
its screwed into the block, near oil filter its easy to do, just remove the connection and it unscrews, use teflon tape when installing new one, use new switch as a guide to locate old one. good luck hope this helps.
Oct 29, 2009 | 1989 Chevrolet S-10 Blazer
How to install correction tape in the GX-6500 Typewriter?
Move carrier to middle with spacebar.
Open lid, remove black ribbon and old correction tape.
Gently pull new tape apart a few inches. attach take-up spool (empty one) to right post.
Pass through right ribbon guide, sticky side faces platen!
Unspool carefully thread through left ribbon guide.
Attach feeder spool to the left post.
Turn the right spool to tighten.
GL
Jul 04, 2009 | Brother Office Equipment & Supplies
Transfer 8mm,hi8,digital 8 to pc
Since my request..Found i could answer my own questions. Brought firewire card with 6 pin socket.Also brought a cable with a 6 pin to fit the firewire card @ a 4 pin on the other end for the camera .Found my install cd. Loaded the USB installation. Got my connection completed between the camera @ the computer.With regard to the tape formats no problems at all.With nero 6 not sure yet.My home movies go back as far as 1989 and the quality is as good as new.Hope SONY don't stop making the dv tapes. With the external hard drives for editing @ storage need an answer for capacity James from Auckland New Zealand.
May 16, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
Installed new colored ink and keeps saying " remove and check colored ink"
The cartridges comes with the protect tape at the bottom please its removed, if removed please clean the copper contacts with dry tissue , if you get the same error try the old cart if you get the same error the printer is faulty or if dont get then the colour cart is defective get it exchange if you had brought original cart as it comes with 6 months warranty...............
Jun 03, 2008 | HP Office Equipment & Supplies
Check Printhead cleaner Path
Sounds
    1. Attempt to duplicate the message by turning the printer on, reloading the media, and printing several test prints.
    2. Note the movement and position of the carriage when the error occurs.
    3. If the carriage stops on the left-hand side (roughly 12 inches from the ink supply station), unplug the power cable from the printer, open the top cover and try to move the carriage to the right. Closely inspect the ink tubes for wear, and check for ink tube binding or catching on the tube guide (stopping/hindering carriage movement). If true, continue with the remaining steps below.
        NOTE: If the steps above do not describe the issue correctly, refer to the work instruction for a typical “Switch Power Off, Check Printhead Path” message (bpp90070).
Check/replace the Ink Tube Systemgtabtop.gif
    1. Turn the printer off.
    2. Remove the old Ink Tube System (refer to pages 8-53 of the Service Manual).
        NOTE: If the printer is installed on a Multi-roll feeder accessory, some additional disassembly is required to gain access to the printer. Instructions for multi-roll disassembly are listed at the bottom of this document for reference.
    3. Move the carriage assembly to the right side of the printer.
    4. Clean the rear tube guide assembly with a moistened lint free cloth to prepare the mounting of the Mylar tape.
      Figure 1:Cleaning the rear tube guide assembly
    5. Remove the backing on the Mylar tape and align the line on the tape with the front edge of the rear-tube guide so that the narrower section is towards the front of the printer. Do not attach the tape yet.
      Figure 2:Aligning line on Mylar tape with front edge of rear-tube guide assembly
        NOTE: Ensure that the Mylar film is perfectly aligned with the rear Tube Guide surface with no protrusions or unevenness.
    6. Carefully position the Mylar tape about 1/4 of an inch from the left-end of the rear-tube guide (do not go all the way to the end as the beveled edge will cause crimping of the tape).
      Figure 3:Attaching the Mylar tape
    7. Ensure tape is evenly positioned and any air bubbles are smoothed out along the tape.
      Figure 4:Smoothing out the air bubbles along the Mylar tape (view from rear of printer)
    8. Carefully fold under the narrow section of the tape to the underside of the rear tube guide assembly and smooth out any air bubbles.
      Figure 5:Installing Mylar tape under rear-tube guide assembly (view from front of printer)
    9. The Mylar tape should look like the image below.
      Figure 6:Final installation of Mylar tape (view from top of printer)
    10. Once the Mylar tape is installed, install the new Ink Tube System (refer to pages 8-53 of the Service Manual).
    11. Following replacement, verify printer functionality.
like a bad belt.
Feb 11, 2008 | HP DesignJet 1050c InkJet Printer
Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Jan 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
