Question about Fujitsu LIFEBOOK S6010 Notebook
How to swap a damaged screen
I have lifebook with a broken screen and another good one with a damaged casing. How do I remove and swap the screens?
  • 35 Answers
Hi
Can give you exact details and step by step instructions on how todo it but what i could suggest is that when youdo take the 2 machines apart make little notes or drawings as to where and what you remove, so when you put the machines back together again you will know where does everything fits.
Its very easy just hand all parts with care and youlle b ok
Good luck
SlitWrists
Posted on May 20, 2009
Our screen is broken may be because foot rested on the screen. How do you take out the screen so that a new one can put in.
Disassembling a laptop is not something that you should "try" by yourself.
If you accept the risks:
* make a "backup" of all your files, just to be "safe"
* turn the computer off
* disconnect the AC power
* remove the battery
* remove the covers over the hinges
* remove the keyboard -- note that a DELICATE "ribbon-cable" connects the keyboard to the case
* remove the top-plate -- by unscrewing some of the screws on the bottom of the case
* unscrew the hinges -- note that a DELICATE cable connects the LCD to the case
* remove the "surround" from around the screen
* swap the screens
* reassemble.
Good luck -- you CERTAINLY will need it.
Dec 24, 2010 | Computers & Internet
A kid intentionally threw the remote control at the middle of the screen, eventhough it's still working, the part that has been hit is already damaged and only 3/4 of the screen is visible
If the LCD panel has been damaged then the tv is a write off, sorry.
Supplying and fitting a new panel will cost more than buying a replacement tv as it's overwhelmingly the single most expensive component. When you buy a new tv you are effectively buying a flat panel at a huge volume discount and all the other parts which make it a tv are thrown in for free.
The tv rental company I work for is the largest such business in the UK and only ever replaces broken panels by cannibalising other tv's which have been returned with other serious and unrepairable faults. In practice the panel is rarely swapped, what usually happens is that the broken screen tv donates its inner workings to a tv with a good panel and outer casing but with serious electronic faults (usually due to liquid damage). The panel only ever gets swapped over if the outer casing to the tv is cosmetically unacceptable.
Oct 08, 2010 | Samsung LN-T4665F 46 in. LCD Television
There is a magenta bar running down the middle of my monitor
this is what's called a broken or damaged Pixel array. the only way possibly see if it will go away is:
1) Remove the AC power from it for a good 1 hr.
2) Slightly bang/tap on the top and or bottom of the monitor bezel - could be a broken solder joint.
3) Replace the screen if it's out of warranty. - would be cheaper to buy another monitor. Cost of the labor will kill you then the cost of the replacement screen.
also look on E-bay to see if their is one that won't power up. You might be able to swap the screens if you are mechanically/technically inclined.
Blessings,
A/V Media Guy
Nov 21, 2009 | Cars & Trucks
My Fujitu Lifebook c1020 display is bad and needs swapping. I need a repair maual.
its pretty simple to change the screen on this computer, and you dont really need a service manual (i dont even think you will find one for that)
the way you do it is remove the rubber "dots" around the screen, there should be atleast 4.
when they are out, and you have removed the hidden screws, you can take of the frontbezel around the screen.
when the bezel is off you might need to loosen or remove 1 of the 2 screwes on each side at the bottom hinge.
the screen itself is fastened to the hinge with 2-4 screws on each side of the screen. remove them, take out the flat/wide cable on the backside, and disconnect it from the 5-6cm long printbord.
reverse the process when you put in the new screeen.
May 28, 2009 | Fujitsu Lifebook C1020 Notebook
My laptop displays very dark
Unfortunately, (Isay that a lot on this site), your lcd screen is backlit with tiny flourescent lights, sounds like these have been broken not much to do except talk to a local tech and hope that he has an lcd screen to swap or steal parts from.
Sorry my prognosis is not better...
Ed Meyer
Owner
AACS
www.alwaysaffordablesolutions.com
May 22, 2009 | Fujitsu LifeBook® S2210 PC Notebook
Lifebook A6020
I had a similar problem before. Try removing the batter pack and use only the power adapter. If it works fine then the problem is your battery and had to be replaced. If not, try changing your power adapter if you have access to a replacement. If it is not available and you are adventurous enough, you have to manually open the wire connecting to your computer (of course you unplug the cable). It is possible that some of the wires are broken due to constant twisting of the cable such that not enough power is delivered to your screen that make it look dull. What I did was cut the damaged portion and reconnect then using a soldering gun.
Aug 29, 2008 | Computers & Internet
Touch screen
Try swapping out the touch screens. It may be that they used different makes of touch screen in these models, and the board and screen are matched. This is the case with many laptop manufacturers. They use different screens in the same models, a cheapest bidder type thing I believe, so, if you switch boards, you have to switch screens or video cards in order to get them to work. Speaking of video cards, does this board have a removable video card or integrated. If it's removable, then you might swap them out if the screen change doesn't work. Try this and let me know.
Aug 15, 2008 | Computers & Internet
Broken lcd screen
I have to tell you that swapping LCD screens are pretty hard especially for phones that you have to open up like this one. Just take the screen to some Cellphone store they might be able to do it. Good luck.
Jun 20, 2007 | Samsung SCH-a950 Cellular Phone
Fujitsu LIFEBOOK S6010 Notebook Logo
83 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
