Question about AEG Lavamat 88840 Front Load Washer
Heater relay c7 Aeg 86741
Is it an easy fix and can I access it fom the top of the MACHINE
3 Suggested Answers
zeusfaber
  • 247 Answers
SOURCE: Problem C2 with AEG Lavamat 86741
Find the drain pump (on most front loaders, it's at the bottom of the machine at the front - often with an access hatch).
Open it up (you may want to tip the machine backwards and put a basin underneath to catch the water - and be prepared to close up again if the basin gets full before the machine is fully drained). Check that the pump impeller isn't jammed with a collection of old coins.
My next move would usually be to set the machine going in a part of the cycle where the drain pump is supposed to be running, and to give the impeller a quick flip with my fingertips (taking great care to avoid injury). If the pump doesn't run until you flick it, but then starts, this is a sure sign that you need to replace the pump motor - a quick, cheap and easy fix.
If the pump starts by itself, the the problem is more likely to be one of blocked hoses.
If the pump won't start at all, either by itself or when you flick the impeller, you need to check whether the pump is getting electricity. Do this by disconnecting the machine from the mains, connecting a voltmeter across the two terminals on the pump, then switching back on and selecting a bit of the cycle where the pump is meant to run. If you see mains voltage, then again you want to change the pump motor. If you don't, then check all the associated wiring before starting to look at the main timer. Disconnect the power before removing the voltmeter connections.
A.
Posted on Mar 05, 2008
SOURCE: AEG OKO_LAVAMAT 74620 gave me a code error C7. What is it?
take off the bottom front panel, a booklet is taped to the right side of the panel for the sevice tech it has all the codes
Posted on Feb 28, 2009
My aeg lavamat 41070 washing machine doesn`t work at high temperature ( more then 50 degrees) . At low temps it is working OK/
In the case of insufficient heating appears error code E60 what means replace the NTC sensor. Exclude heater, PCB or relay malfunction because you indicate that the machine is heated to 50 degrees Celsius.
Dado
Feb 28, 2015 | AEG Washing Machines
Aeg lavamat error code c6
Found this on the following forum
http://www.ukwhitegoods.co.uk/forumsphpbb3/washing-machine-forum/aeg-lavamat-86741-error-t47666.html
C6 is caused by either a) defective mechanical pressure switch, b) defective pressure sensor or c) Defective wiring to either a or b.
You may want to just remove the hoses from the switch & sensor, noting what hose went where & blow down them to see if they are clear. If not, trace blockage & clear, refit hoses & test.
Before doing the above, please isolate the appliance from the mains electric supply.
Jan 13, 2015 | Garden
AEG Lavamat 88830 Update Gives me the code C7. Whats wrong?
C7 error is th\at no heating of the water has happened. check the heater (most likeley) also can be faulty relay on electronic. ntc fault, pressure switch or wiring to any of them.
Nov 09, 2010 | AEG Lavamat 88840 Front Load Washer
Feb 28, 2009 | AEG Lavamat 72640 Front Load Washer
AEG DISHWASHER, DOES NOT HEAT WATER.
I had this same problem on our AEG dishwasher. The reason was on the controller board. There is one relay switch which drives the heater element.One of the legs of that relay box was disconnecteds from the circuitboard. Check this out.
Sep 25, 2008 | AEG 18 in. Favorit F54850 Slim-Line...
A.
Mar 05, 2008 | AEG Lavamat 88840 Front Load Washer
AEG OKO LAVAMAT 86741 UPDATE. WASHING MACHINE
I have washing machine AEG 62800 model.
When I tried to start a washing the error E60 was displayed on screen.
The following actions were done:
1. Turning knob to right to first position "COTTON LINES 95"
2. Pressing on all 5 functions except START button (Rinse Hold, Rinse+, Time Saver, Pre Wash, Stain).
Red lights will flash .
3. Pressing on Start button and simultaneously starting to turn clockwise till OFF position.
It will reset error and will release machine.
I'm hoping it will help.
Boris.
Feb 25, 2008 | Washing Machines
AEG Lavamat 88840 Front Load Washer Logo
23 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
