Question about Garden
Mac cat 839 fuel line layout - Garden
3 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: I have a walbro WT349 on a mac cat 38cc. chainsaw
Leave the hoses a little long an try it. Logic says the uppermost carburetor connection goes to the priver bulb, but you and I both know logic does not always work.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
McCulloch IPLs (600160) You provide the prefix and suffix.
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
HTH
Lou
Posted on Feb 07, 2010
  • 4088 Answers
SOURCE: how do u set the
Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H jet needle CW until the engine starts to speed up. Correct adjustment is when the engine 4-strokes at speed unloaded, but 2-strokes immediately when cutting. Release the throttle and adjust the L jet screw CW for better idle, yet allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the engine continues to run, but the chain doesn't try to turn. Hope this helps!
Posted on Nov 05, 2010
Service manual for mcculloch mac cat 600038-30 chainsaw
fuel line is available by the foot from a mower shop
most fuel leaks involving lines and tanks can be traced to the rubber grommet at the lines to tank entry
take it to a mower shop and discuss the fix
Oct 20, 2016 | Cars & Trucks
Where is fuel filter located on a 2007 Arctic Cat?
Here is a link to the parts manual - do not see one.
https://docs.google.com/file/d/0B8Mnqm7Be8K8ZDU3YTJhZTgtODIwYS00ZjAyLWI3ZjctNjFlMTcwODk0ZGMz/edit?num=50&sort=name&ddrp=1&layout=list#
Mar 03, 2015 | Arctic Cat 2007 F5 EFI LXR
Was wondering if theres a gaskit for the fuel line keeping gas from leaking out where the fuel line exits the tank
Typically the fuel lines have a fat spot with built-in retaining rings that squeeeeeeeze tightly into the plastic fuel tank opening. The fuel lines are easily destroyed during removal and easily damaged during installation... Be sure to coat the swelled up portion liberally with oil while reinstalling....or get ready to buy another one if available.
Oct 05, 2014 | McCulloch Bar Bolt Mac Cat Titan 7 355 365...
What is thesharpening angle for mac cat 330-839 chain
25 - 30 degrees looking down on top of the chain.
Drop the handle end of the file no greater than 10degrees.
If the chain has been sharpened more than 3 times please check the "height" of the "raker" in front of the chain tooth on the chain.
As a general rule these rakers have to be lowered to allow the cutting edge of the tooth to "bite" deeper.
Aug 29, 2014 | Garden
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
How do u set the darb screws on a mac cat 839 chainsaw
Nov 05, 2010 | Garden
HTH
Lou
Feb 07, 2010 | Garden
Where can I purchase more track for this toy train set? CAT Iron Diesel Train Set found at ToysRUs, Meijer, Target.... The track included makes a small oval, would like to have more track so the train...
CAT Iron Diesel Train Set's price decreased by 56% from $44.99 to $19.99 at Amazon.com. CAT Iron Diesel Train set. Easy assembly just push track together. Create multiple layouts. Requires 2 AA Batteries not included
Sale Price: $19.99, Vendor: Amazon.com Full Details
Sale Price: $19.99, Vendor: Amazon.com and/or Amazon.com Merchants
Dec 29, 2009 | Toy State CAT Iron Diesel Train Set
Fuel leak mitsubishi pajero 2.8 automatic
check the hose clamps on the rubber lines from the fuel filter to steel line. you can also trace the lines from there
Jul 28, 2009 | 1995 Mitsubishi Montero
Layout/Printing issues
FileMaker 5.5 is a long time ago for me, but I think I will try to answer your question (although it is likely you have a solution or no longer need one.) While in layout mode, while working on the layout, go to printer setup and choose the printer and page size you will be printing to. This will cause FileMaker to have a dashed line where the printer pages are on the layout. Anything that extends over these lines will require additional pages to print. Simply bring everything back in before these lines to limit to 1 page (including the blank space at the bottom of the page. There is a tab you will need to drag above the page break line to prevent a second page from printing. Additionally, if you cannot work it out, while printing from FileMaker if you choose the page range of 1 to 1, only 1 page will print, however, doing this prevents you from printing additional records without writing a script to do it. However, if you are able to redesign the layout to only print 1 page then you will notice there is an option on the print dialog box that indicates something to the effect of "Print current record" and "Print records currently being browsed" (Don't remember the exact wording in FileMaker 5.5); Choosing the records currently being browsed option will print all records in your current found set.
I hope I've done a good job answering your question. I am a FileMaker expert for version after 7 and have used Filemaker since version 4; if you have any additional questions I will do my best to answer them. If my answer was helpful for you I'd appreciate a 5 thumbs up rating, or a click on the yes this was helpful button. Thank you!
Apr 06, 2009 | FileMaker Server 5.5 (540100U) for Mac, PC
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
