Question about Samsung CLP 300 Laser Printer
Invalid black toner replacement cartridges
I recently bought replacement black toner cartridge for CLP300. Tried to install it and got invalid cartridge message. checked cartridge and the replacement cartridge has 4 gold contact points whereas all four original cartridges only have a hole. I thought the problem was because I bought the GENUINE cartridge from the USA via Ebay so ordered another one from the suppliers in Greece I bought the printer from in Dec 2008. SAME problem. I have now spent 100 Euros and still can't print anything.
  • Ruth Hackney
    Ruth Hackney May 21, 2009
    How do I know which version printer it is and which area the cartridge is sold for?
    Problem Solver:
  • 9 Answers
Hi, Please make sure what version printer you got? USA version? or Asian version or euro version?
After confirm what version printer you got buy corect version CHIP or toner it will works.
Use any of other area toner will result toner invalded.
Regards
Posted on May 20, 2009
My xerox 6600 keeps saying "invalid black" when replacing cartridge
The CHIP on the NON OEM cartridge is NOT current with correct firmware and as a result the cartridge(s) will NOT reset that a new cartridge has been installed.
Future hint...do NOT update as working printer drivers "ever"...as this is one way that the OEM's thwart the aftermarket TONER usage.
Good luck
Mar 13, 2016 | Xerox Phaser 6600DN
Samsung CLP300 black & yellow cartridges do not have chips on them
No, the black and yellow toner cartridges does not have chips because they are "starter cartridges", to solve your problem you must execute a "PERIODIC DEFECTIVE IMAGE" readjustment, you can download the service manual from here:
http://www.tradebit.com/filedetail.php/229896734-samsung-clp300-series-clp-300-xsg-service
Best regards,
Jul 14, 2013 | Office Equipment & Supplies
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
Phantom paper jam . Samsung clp300. Flashing red light
you clean your printer drum unit wast ink poder drum open and wast ink
Jul 21, 2009 | Samsung CLP 300 Laser Printer
CLP 300 toner cartridges invalid toner
the drum has chips encoded,need cartridges with chips.
May 29, 2009 | Samsung CLP 300 Laser Printer
Invalid toner black
The issue with refills is that sometimes you get a bad one where it will do this. The only solution would be to purchase a genuine cartridge.
Mar 27, 2009 | Office Equipment & Supplies
"invalid toner cartridge" message remains
Try this
Turn the printer off hold down the menu button turn the printer back on while continuing to hold down the the menu, when you get a green light your ready to print
Feb 18, 2009 | Samsung CLP-510 Laser Printer
Samsung ML-2152W
The problem is that the cartridge you re using was reloaded with toner, but the remanufacturing process did not include replacing the chip. The ML2150 and the 2151N do not read the toner's chip on boot, but the 2152W does. So you either have to get a cartridge that has a new chip or get a new, genuine, Samsung cartridge.
Jun 01, 2008 | Samsung ML-2150 Laser Printer
Samsung CLP 300 Laser Printer Logo
828 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
