Question about Nordic Ware 62301 Famous Micro-Go-Round
Micro-go-round repair will not turn
I have a kitchen aid microwave and when turning on sounds like the bird chirping around the bottom of the unit.
Does it have the option to turn the turn table off if so turn it off and see if noise goes away if so turn table motor very common over time it will default back to on on next cycle
Feb 20, 2015 | Microwave Ovens
What is the probable cause of the fan turning itself on?
To diagnose i would check if the fan "always" turns on in the start of microwaving a meal? and or if it gets hot and then "always" turns off at a certain time?
if it always turns on and then turns off at a time such as 30 seconds, probably getting hot and over heating - replace fan motor
if it turns on for the first meal but then is off or on intermittenly probably a switch or wiring is loose.
Jul 03, 2014 | Electrolux Microwave Ovens
Why turntable will not turn
You either have a bad turntable motor, or else a bad (broken) shaft coupler.
May 08, 2014 | Kenmore Microwave Ovens
I ruined the part that turns the glass platter
It's not safe to disassemble or repair a microwave oven yourself. I would not try to use the damaged 'rotate' feature (you might invert one of those plastic microwave-safe plates above the spinner to avoid using it). However, I highly recommend a repair shop or (better yet) get a new microwave for $50 and be safe.
Dec 02, 2013 | Panasonic NNSN797S Microwave Oven
JVM1740DM1WW
There are three microswitches. All are interchangeable.
This will give you the idea.
V3 Microswitch SPDT 16A Micro Switch eBay
Match the type of actuator and order a couple.
Aug 14, 2017 | GE Microwave Ovens
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
Jun 16, 2013 | Microwave Ovens
Turn table won't turn on ewave microwave oven
Almost certain if microwave still heats a bad motor or gear issue inside the unit--if unit will not heat the safety switch in the side that the door engages is the cause of the wheel or platter not turning--prevents unit from use if door open.
Nov 06, 2012 | Microwave Ovens
My rollers don't turn
may sound stupit but are the rollers clean and does the pice in the middle that turns them turn when its not in or is the wrong playe in there or your belt could be broken that turns it
Sep 28, 2012 | Microwave Ovens
Microwave turns on but will not heat
Unplug..check breakers..restart if possible..Call tech. Diagnose problem..if easy to repair order part from this website. repair manual to repair and part numbers are usually in the panel selection panel of the micro
Jun 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Nordic Ware 62301 Famous Micro-Go-Round Logo
121 people viewed this question
Top Nordic Ware Microwave Ovens Experts
William Miller
William Miller
Are you a Nordic Ware Microwave Oven Expert? Answer questions, earn points and help others
