Question about JVC UX-GN6 120 Watts Micro Component System Shelf System
Locked cd drawer - JVC UX-GN6 120 Watts Micro Component System Shelf System
How do I open the cd drawer?
Look for a small tiny hole right below the CD drawer, use a paper clip and insert. That hole if made for when a CD is stuck and the drawer will not open, its more like a manual lock and needs to be pushed in with a small metal wire to unlock the drawer, mind you that the computer has to be running.
Mar 05, 2015 | Dell XPS 8700 Desktop Computer; Intel Core...
How to open cd drawer
Oh my God, the answers I\'ve found on the net on how to get the CD drawer on a Crosley CR247 open are all nuts. Mine wouldn\'t open yesterday and I dismantled the whole damn thing to get the tray open, but that isn\'t necessary.
First of all my unit was making noise when I hit the eject button but the drawer wouldn\'t open. I knew there was no CD in the tray. Powering down and all the other foolish answers I found didn\'t work. There is no small round hole in the front to do a manual eject. Trying to pry the door open won\'t work and you\'ll just damage the unit. Here\'s what you need to do. And do it all GENTLY. There is no need to force anything!
Take a small, pointed steak knife out of your kitchen silverware drawer. This is all you\'ll need to get the drawer open. First let\'s identify where we\'re going to put that knife blade. The CD drawer says "CD RECORDER" and there are 3 lines on each side of that label. Where you\'re going to put that knife is below the 3 lines on the left, to the left area of those lines (see picture). This is the location of the drawer lock.
If you still hear noise when you push the eject simply push in the knife gently as you push the eject button. The drawer will open if you got the right spot.
If you hear no noise, or your unit is dead and you want the CD out, or if you\'re just afraid to stick the knife in the unit, unplug the unit. Gently push in on that spot until the drawer pops out a little bit. Now you can gently open the drawer by hand.
You can see the drive belt and pulleys (see pic). Mine was still intact but needs replaced. Here is also the info I got off of the back of the CD (see pic). Might not be able to find a replacement belt but at least you can get the thing open. Good luck.
jim Maarrttiin@msn.com
Mar 04, 2014 | Crosley CR247 Shelf System
Dx7355 locked
Set your Player back to Factorysettings. Push "Skip forward" and "Repeat" at the same time. "Clear" appears on your display.......now you should be able to open your deck.
Jan 13, 2013 | Onkyo Dx-7355B Cd Player - Black
Dvd drawer locked and dvd wont play
Is it a store purchased dvd movie or is it a dvd that someone made and gave to you? Computers sometimes have problems reading cd's and dvd's that someone made. Try a store purchased movie dvd or music cd.
When you press the button on the dvd drawer it does not eject? Clcik Start/My Computer then Right Click on the DvD Drive and click Eject.
If it still does not open, take a Gem Clip (Paper Clip) and straighten it out as much as possible. Then look at the DvD Drawer and you will see a tiny hole that you can insert the Gem Clip (Paper Clip) into. Push the Gem Clip (Paper Clip) while you press the button on the Dvd Drawer and drawer will open. Don't worry about damaging or breaking something, that is why that tiny hole is there.
May 16, 2012 | Computers & Internet
My jvc compact component system cd drawer won't open
The loading belt is broken, or the gears are jammed and locked down, either way a major dis-assembly will be required to attempt repair.
Mar 27, 2012 | JVC Audio Players & Recorders
Sony CD player CE-415 Drawer will not open.
This will require a professional, the more CD'S this unit can take the more complicated the loading bay will be. The most common problem is gear timing where the system is knocked out of sync and often locks down the device to prevent further damage. Sometimes the gears will strip jamming whole mechanism.
Mar 15, 2012 | Sony CDPM400CS 400-Disc MegaStorage(r) CD...
Motor driving CD drawer seems to have failed. Model CDP-502 Jammed in close position
More than likely, the drive belt is slipping. The drawer is locked when in the full load position. It can be opened by hand with access from the bottom. I will try to get a picture loaded later today to show the procedure.
Dan
Oct 21, 2009 | Sony Audio Players & Recorders
CD drawer will not open
Hi
maybe you have defective mechanical ejection! maybe the lock is stock. this is need to open to hook up the lock
thanks!
Likha
Oct 23, 2008 | RCA RCD150 Radio/Cassette/CD Boombox
Jammed cd drawer
The best solution is to take off the top cover. It's easy to remove with, I believe, four screws. The carousel is located right underneath the cover, so all the CD's will be exposed. However, I don't think that this will solve the problem of not happening again, since this seems to be a problem with this particular model.
Oct 05, 2007 | Panasonic SC-HT740 System
TEAc HMX-760 "CD Drawer" was removed
you lost the cd tray timing,caused by force- eject,so you need proper alignment,you,needs specialist.
Feb 05, 2007 | Teac DC-D2831 CD Shelf System
JVC UX-GN6 120 Watts Micro Component System Shelf System Logo
22 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
