FixYa.com
Tags:
Sony RDR-VX525 DVD Recorder / VCR Combo
Disk error (by 6 users)
posted by bjhera on Oct 18, 2007
Won't read any disks, have cleaned it, tried multiple disks starts to read then it says disk error
5 carousel cd
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by Guest, posted on Dec 28, 2007
SONY SLV-D350P DVD/VCR Combo:
When disc is loaded, "Loading" is displayed on monitor, and disc spins for about a minute. Disc stops spinning and "Stop"...then "Error" is displayed
on DVD display. Message window says: "This Disc cannot be played...Check Disc." Tried another good known disc with same results. Also cleaned Laser Lens with special cloth. Unit is about 3 years old, and randomly developed this problem without warning.
Comment by jlove7, posted on Dec 23, 2007
it wont finalize the disc it will do it sometime its a big problem
Comment by Guest, posted on Dec 08, 2007
can not read any dvd disks.
Comment by Nukum, posted on Dec 05, 2007
A similar problem occurs on my machine. It will record OK but when finalizing it errors after a few minutes and renders the disk unusable and unreadable. The unit is only 6 mo. old but has several hundred hours of record time. I will be sending it back to the factory for warranty repair.
Comment by Donald9, posted on Nov 28, 2007
Backup copy of DVD's will not play on SD-V392 or SD-V290
Clarification Request
by FrusTrat713, posted on Feb 02, 2008
Why would a practically new laser go bad? I can see it being bad out of the box - stuff happens. But the laser should not go bad after only 10 or 20 hours of use, or even 100 hours!
Solution #1
posted on Dec 24, 2007
Not Rated (0)
pedeohh
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had the same issue with this DVD player. I noticed the problem after running the firmware upgrade. I could do nothing to fix the problem and neither could the Phillips support line. Luckily I purchased an extended warranty, too bad the player went out before it kicked in. The one 1yr Phillips manufactures warranty had to replace the unit with a new upgraded model.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Nukum
Rating: 82%, 5 votes
Thanks, I can hear the disk spin. It also makes a knocking sound every 5 seconds while it tries to finalize until it errors and then stops. It's very quiet when just recording. I was thinking the spindle had worn down enough to cause the disk to not spin true anymore but I didn't think about the laser going bad. If it wasn't under warranty I would open it up and see for myself.
Solution #3
Not Rated (0)
ctf1800
Rank:Wiz Wiz
Rating: 85%, 3055 votes
can you hear the cd spin?
more times than not the laser is bad.
Can you Help with these DVD Players problems?
Copy from VHS c to DVD
I can not seem to convert from... Answer This...
any DVD intermittently...
Any DVD (movie, music)... Answer This...
No Sound
Hi, I hooked everything up from... Answer This...
No Audio from HDMI connection...
I have tried connecting via... Answer This...
How to Record TV Programs w/o...
I recently purchased a Sony... Answer This...
Repair Service
Find DVD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
