Question about Mazzer Coffee Makers & Espresso Machines
Reset shot counter - Mazzer Coffee Makers & Espresso Machines
Activate juki ddl-8700-7 bobbin counter
good luck i have 12 juki auto machine and no one can figure that out!!! that panel on top should be shot.
Jul 28, 2012 | Juki DDL-8700
How do you reset the counter when shooting video?
The resetting of the counter is not a problem. As a matter of fact you can not reset it because it is meant to be continuous as long as the video is the same. However there is way around it. After recording your first part when you want to reset you go to 'play'. You play forward for less than a second and stop. When you go back to record the camera resets itself and thinks its starting a new video. It goes back to 000. You keep on doing this when you want to reset again. Normally in professional circles the time code should be continuous for editing with professional Non linear editing software that's why the cameras do not reset the time code. But you can get along the way I have told you here for your purpose.
Oct 27, 2011 | Panasonic PV-GS39 Mini DV Digital...
I have to reset the copy count in canon LBP-3300. please help me.
it's not possible to reset the counter manually. For reseting the counter you need to replace the video controller pcb
Mar 01, 2011 | Canon LASER SHOT LBP 3300 Printer
How to reset picture counter numbering on Sony dsc H50... Thank You...
If it works anything like a DSC-W230 then copy all files from your camera usb stick to backup medium. then delete all files but one from the memory stick, using a usb card reader capable computer rename the one remaining file from [example] DSC00001.JPG to DSC01241.JPG, any subsequent pictures should increment properly. if you want to just reset to factory state and start from 001 again just hard reset the camera as per the owners manual instructions. Don't bother with Sony tech support on this issue, the either don't know how to do this, or are not allowed to tell you this, they told me I could not reset the numbering after my daughter did a hard reset, but I figured out it was possible to get it back to where I was at
May 20, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
Printer won't work, note reads thInk well asborer needs replacing
The waste ink absorbers are a couple of pads at the bottom of the printer. Contact Canon (or a service center) if you want to buy a replacement (not all manufacturers sell them). It can be hard to reach the pads but give it a shot. If you are reusing the pads, rinse them with running water until it runs clean. Then once they are dry, reinstall them and put the printer back together.
Then you need to reset the printer waste ink counter:
With the printer connected to power but not on, press the Power button while holding the Stop/Reset button. When the power light is lit, continue to hold the Power button and press the Stop/Reset twice. Release both button (in any order). The printer will now enter the service mode.
When the green LEDs are lit, press the Stop/Reset button 4 times to get to the Waste ink counter reset. Reset this value. Then press the power button (saves the setting) and then restart the printer.
I hope this helps.
Apr 30, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Print counter each day
if the printer is on a network it has an ip address. find out what it is and simply type that into your web browser. It will get you all sorts of specs on the printer including ink usage and page count. I doubt it has a a counter you can reset everyday but you can use some simple math if you remember to look at its total in the beginning of the day.
Apr 06, 2010 | Canon LASER SHOT LBP-2900 Printer
Blinking Red Lights
You need to reset the ink head shot counters and protection counter. Basically the printer has worked out that the waste ink pad is full. It often isn't. Google SSC Service Utility, install it, and select your printer and model in the lists on the tabs at the top. When it's running, turn the printer on, and right slick on the SSC Icon in your System Tray (near the clock). Reset the protection counter, and head shots counter. Perform a reset of the printer, and you should find that the problem has gone away.
Mar 14, 2009 | Epson Stylus Photo R300 InkJet Printer
SERVICE REQUIRED ERROR.
Uninstall SSC Service Utility, and reinstall the drivers for the printer. Reinstall SSC and clear the protection counter, as well as the Head Shots counters.
Mar 05, 2009 | Epson PictureMate Deluxe Viewer Photo...
Nikon d80 frame count
264 is the minimum number of shots you can fit onto the memory card. A shot with large areas of black or white uses less memory than a more complex image and so the camera recalculates the number of shots remaining and so the number appears to go back up to it's original value.
Sep 10, 2008 | Nikon D80 Digital Camera with 18-135mm...
Sony cyber shot
How do you know it is not your camera's display screen. Download pics to computer to verify. If you do not have a computer, take mem card to a retail photo Kiosk or counter; walmart, drugstores, etc.
If they are still white after reading card, and a pick file exists, then it is probably the Record Mode, pic taking mode, of the camera that is defective, of some setting out of whack.
Try removing the cam battery and reinstall after a 10 sec waiting time. This will reset the camera and put setting back to DEFAULT mfg settings.
Apr 07, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Coffee Makers & Espresso Machines Logo
46 people viewed this question
Top Mazzer Coffee Makers & Espresso Machines Experts
Brett Duxbury
Brett Duxbury
Bill Boyd
Mister Danger
Are you a Mazzer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
