Question about Canon SELPHY CP720 Printer
I Put a new ink cartridge but my canon selphy 510 say it is empty, I have tried with several cartridges but the same, any advise, thanks
3 Suggested Answers
SOURCE: Canon Selphy 510
I have a similar problem saying that the cartridge was not installed. Try winding the film on until you can just see the yellow film and try printing again. This normally fixes my problem for that print run, but the problem seems to regularly re-occur. Hope this helps.
Posted on Mar 04, 2008
JULIANFIX
  • 975 Answers
SOURCE: I just put 2 new ink cartridges in my Canon 210
if your getting this reading directly from the printer ,then I suggest to go where there is a set up button and go for the default setting, with the cartridges already inserted . if reading coming from your comp. , then I suggest to re configure the printer s software. let me know , hope it helps AJ
Posted on May 08, 2009
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
Can't remove ink cartridge selphy cp750 ink cartridge
I tried winding the gears and as soon as the gear reaches the correct alignment, you can eject the cartridge
Apr 22, 2013 | Canon SELPHY CP750 Printer
Selphy cp780 continues to say ink cartridge empty even after installing new one. Tried 2 new ones to be certain it wasn't the cartridge, same thing...tells me ink cartridge empty install new.
try and reset your printer,unplug the power cord and wait 10 min, then plug back in,understand that Canon has installed a chip so you cannot use refilled cartridges,or cartridges you refill,if this doesn't work,then contact Canon,and you could get the same message I got take it in to be repaired, (to costly), so I end up buying a new one,,
Oct 10, 2012 | Canon SELPHY CP780 COMPACT PHOTO...
Cannot remove ink cartridge in canon selphy
is one of the gear having the problem in the canon selphy cp 760 photo printer ... the last motor gear loses.. just add super gule to it.. due to the gear is loses.. so the print cartridge can`t releass out...and it keep say your cartridge in empty... turn the gear n it free your print cartridge...
now everthings look fine...
Aug 27, 2012 | Canon SELPHY CP760 PHOTO Thermal PRINTER
I have a Selphy 710 that I've seldom used. Now when I insert a new ink cartridge, it cycles to the end and error box says "Ink cassette is empty and must be replaced." I've replaced the...
I'm having the same exact problem with my CP730. The paper size and ink cartridge are the same size. I've tried two new ink cartridges, same result. Frustrating and expensive.
Mar 09, 2011 | Canon SELPHY CP710 Thermal Photo Printer
Cannon selphy es2 - how do i remove old cartridge?
you can remove the old ink cartridge from the Canon selphy es2 by simply lifting the small green lever on the ink cartridge carrier. Take note of how the cartridge was situated in the carrier, then gently take the old cartridge out of the printer.
Jan 18, 2010 | Canon Office Equipment & Supplies
Canon Selphy 510
Hi! I have same problem. I opened cover (4 deep screws at the bottom) and found small plastic gear was separated from stepping motor shaft. I fixed it on shaft and my printer started work again. Today I will try to fix same problem on another CP510. I think same reason. Try to do it. Simple. vadim.y.astakhov@gmail.com
Feb 29, 2008 | Canon Selphy CP510 Thermal Photo Printer
Canon SELPHY  CP720 Printer Logo
old marine
old marine
