Question about Nordic Track Exercise & Fitness
Nordictrack a.c.t.elliptical makes clicking noise
ercupa190
  • 12223 Answers
SOURCE: I have a NordicTrack SL710 recumbant bike that the
Prepareto oil by filling a grease gun with lithium grease. Check your owner's manualfor the exact type of grease for your unit.
Posted on Nov 03, 2011
ercupa190
  • 12223 Answers
SOURCE: NordicTrack SL710 pedals slip and make a clicking
Kneelnext to the left side of the elliptical's base. Use the Phillips screwdriver totighten the two screws located in the center of the left pedal.2
Use theAllen wrench to remove the bolt securing the left pedal arm to the pedal legand body arm. Use the Phillips screwdriver to remove the screw securing therear end of the pedal leg to the crank arm.3
Pull theend of the pedal leg free of the crank arm. Wipe the crank arm clean, thenapply a fresh coating of machine grease or silicone lubricant. Replace the endof the pedal leg back onto the crank arm and use the previously removed screwto secure it back into place.4
Join thefront end of the left pedal arm to the ends of the pedal leg and body arm. Usethe previously removed bolt to connect the pieces together.5
Move to the right side of the elliptical and repeatthe above steps on the right pedal arm
ercupa190
  • 12223 Answers
SOURCE: Nordictrack T5.7 incline makes clicking noise
cleal the contacts relais, and replace if necessary. Of course your LUBE the gear and shaft too.Test the elevation motor for problem bearing for repair.
sincerely. God bless you
Posted on May 03, 2012
ercupa190
  • 12223 Answers
SOURCE: My NordicTrack E5 vi Elliptical is squeaking really bad. How do I fix this problem?
go to :http://www.ehow.com/how_4681374_fix-elliptical-machine.html
God bless you
Posted on Jun 09, 2012
ercupa190
  • 12223 Answers
SOURCE: Nordictrack Asr 1000 Elliptical Resistance Motor
1) Adjust the cable tension
2) Adjust the magnet, for loose bolt, test the magnet with the refrigerator magnet, for repulsion and attraction, Replace if necessary buying in any Hardware store, for small price.
God bless you
Posted on Jun 11, 2012
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
www.fixya.com/search/p3944353-nordic...cx1055_elliptic/resistance
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ...
www.shopyourway.com > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...2...
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
Elliptical noise
These motors has plastic gears...gears may be or is getting bad.
Dec 27, 2013 | Nordic Track NordicTrack CX 925 Elliptical...
Nordictrack 1300 elite elliptical manual
go and download the instruction manual and follow the instr.
normally the batteries goes under the display board.
However follow the instr manual
www.fitness.manualsonline.com
God bless you
Dec 15, 2012 | Nordic Track Nordictrack Elite 1300...
My NordicTrack E5.7 Elliptical is making a grinding sound
Hi Liz,
The only way to assess is to take the covers off. There are a few reasons for this type of problem.
Nov 07, 2012 | Nordic Track NordicTrack E5.7 Elliptical
Nordictrack cx1055 vibration problems
see the next steps: Lube and use the logically. God bless you
Inspect the leveling feet on the rear stabilizer of the elliptical. Note if both sides are not flush to the floor. Unplug the machine if they are not flush to the floor.
  • Turn the leveling feet on one side or both with your hand until they are fully in contact with the floor so the machine will not make noise and tilt sideways during workouts
  • Plug in the machine. Use the machine as normal and listen for any noises. Clean and calibrate the ramp again if there is noise but the machine doesn't rock, and adjust the leveling feet again if the elliptical wavers.
  • Aug 05, 2012 | Exercise & Fitness
    NordicTrack CX 1055 Elliptical ramp pedal wheels
    Hi, You can find them easily on amazon, click here ant take a look: Amazon com Elliptical ramp pedal wheels. Wish you best of luck. Cheers
    Jun 22, 2012 | Exercise & Fitness
    I have a NordicTrack SL710 recumbant bike that the pedals slip and make a clicking noise?
    Oct 31, 2011 | Nordic Track NordicTrack Treadmill, A2550
    NordicTrack SL710 pedals slip and make a clicking noise?
    Exercise & Fitness Logo
    Top Nordic Track Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Electro Med Services...
    Paul Sikkema
    Paul Sikkema
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
