Question about Compaq Presario V2401CL Notebook
Blank screen when on with 1 long beep and 3 short beep
Hi guy i install the upgrading for my V2000 (V2401AU) bios and after it install half way it hang. I need to remove the battery to shutdown it. After which when i put back the battery and on the screen is blank and 1 long beep with 3 short beep.
    Scholar:
  • 106 Answers
Start your pc when you get to the screen that shows in the top right corner F2 & F12 at this time press F8. At this point you can either scroll down to and click on " Last Good Configuration" this should the problem.
Good Luck =)
Posted on May 20, 2009
  • tonyh2011 Sep 17, 2011
    this was an amazing fix. It worked perfectly. I couldn't believe how simple it was. THANK YOU.
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
http://www.computerhope.com/beep.htm
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
What is wrong when my compaq v2000 beeps 2 times loud when I turn it on but no boot
Beep codes are unique to each brand of computer:
Compaq v2000
1 short with 1 long beep = bad bios. Must reload bios from disc.
2 short beeps = general bios failure
for more - do a google search for "v2000 Beep Codes" and go to the link for "bioscentral" - all are listed.
Jul 02, 2014 | HP Compaq Presario V2000 Notebook
3 beeps on startup
Below are IBM BIOS Beep codes that can occur. However, because of the wide variety of models shipping with this BIOS, the beep codes may vary. Beep Code Description Document No Beeps No Power, Loose Card, or Short. CH000312 1 Short Beep Normal POST, computer is ok. No problem 2 Short Beep POST error, review screen for error code. See screen Continuous Beep No Power, Loose Card, or Short. CH000607 Repeating Short Beep No Power, Loose Card, or Short. CH000607 One Long and one Short Beep Motherboard issue. CH000607 One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. CH000607 One Long and Three Short Beeps. Video (EGA) Display Circuitry. CH000607 Three Long Beeps Keyboard / Keyboard card error. CH000304 One Beep, Blank or Incorrect Display Video Display Circuitry. CH000607
Mar 26, 2013 | IBM ThinkPad Computers & Internet
I have an HP NetServer E800 when i power on it beeps 4 times then no signal on screen???
Code Beeps POST Routine Description
16h 1-2-2-3 BIOS ROM checksum
20h 1-3-1-1 Test DRAM refresh
22h 1-3-1-3 Test 8742 Keyboard Controller
2Ch 1-3-4-1 RAM failure on address line xxxx*
2Eh 1-3-4-3 RAM failure on data bits xxxx* of low byte of memory bus
46h 2-1-2-3 Check ROM copyright notice
58h 2-2-3-1 Test for unexpected interrupts
98h 1-2 Search for option ROMs. One long, two short beeps on checksum failure.
B4h 1 One short beep before boot
Jul 29, 2010 | HP NetServer E800
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
Same problem
hi, there could be a hardware conflict, can you please reset your bios settings to defaults?
1. reboot your laptop
2. press "F2" - you should see a BIOS menu
3. Look for a keyword "reset to defaults"
4. Save and exit.
Aug 09, 2009 | HP Compaq Presario V2000 Notebook
Blank sreen after bios update
Update BIOS with Boot Block Error Code/Beep:
Definitions Error Beeps Error Code (Port 80H)
BIOS updated successfully. 2L-1S-1L F1h
The BIOS file size is not equal to the BIOS ROM size; wrong BIOS file. 1L-1S F1h
The BIOS file can't be read; it is defective. 1L-2S F2h
The model ID is mismatched; wrong BIOS file. 3S F3h
The BIOS ROM has failed to be erased. Try to flash again. 2L-1S E1h
The BIOS ROM has failed to be programmed. Try to flash again. 2L-2S E2h
No diskette, or cannot locate the BIOS file.
Try to use a new formatted diskette and copy the BIOS file again. 2S D1h
Mar 27, 2008 | Acer Aspire 1640Z Notebook
Bios upgrade error
re-install the old bios. evidently the new flash bios is not compatible with your machine.
Sep 11, 2007 | IBM Netfinity 5500 M20 4RY (86624RY)...
Wont even load onto bios.
you could be right but it's hard defining beeps but i would reseat your memory and graphics card as 1 long and 3 short beeps refers mainly to graphics
Aug 28, 2007 | ASUS A8N-SLI Premium Motherboard
Computers & Internet Logo
237 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
