Question about Zoom 5241 Modem
Thomson dcm 476 blue lights blinking - Zoom 5241 Modem
What does 3 flashes on the standby light on a Thomson scenium 44jw 611s mean
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Feb 25, 2015 | Thomson Televison & Video
On my marathon dcm-2000 mkii it is blinking the first two lights of the volume limit how do I fix it or is it even fixable
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Sep 07, 2012 | Cars & Trucks
Thomson tv projection "52" light blinking.
It apears you have a low voltage problem. This is not an in home repair and may be time to consider purchase of new model. Hope this helps good luck
Jul 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Thomson modem problem
Hi there.
The modem needs to be hard reset, on the back or underneath the modem you should find a small hole or button, you need to push this button and keep it pressed in for around 1 - 2 minutes, release the button and give the unit another 2 minutes to settle.
The wireless light should then go green or stay a static orange (not blinking)
If this does not resolve the problem it may need a firmware update.
Good luck
Jun 12, 2009 | Thomson Computers & Internet
I have A thomson rca dhg535 from comcast.I disconnected the box to move it.After I reconnected it, all the lights came on,but the link light keeps blinking
There is a reset button on the back accessible only by a pen or paper clip. the dhg535 has an internal battery and needs to be reset every time the connection changes or is removed.
Apr 07, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
I have an RCA Scenium HDTV DLP, Model HDLP50W151. Turned it on and went through it cycle, whining sound but the screen was gray. turned it off and then on again...no picture and there was no whining sound....
Sounds like the Color wheel on the Light engine has failed. Its a major repair. Contact Thomson at 1-866-465-7157 to find a local authorized repair center.
Jun 04, 2008 | RCA Televison & Video
Only two lights on DCM 200
have you reset the modem by holding in the buttom either under neath or at the back of it for at least 20 seconds try that
Dec 19, 2007 | D-Link DCM 200 (DCM-200) Modem
Rca cable modem...
This one is for a DCM 315, it should be pretty close and might work. http://a1212.g.akamai.net/7/1212/6718/20030131/comcast.download.akamai.com/6718/help/cmdrivers/RCA_315.zip
Jun 20, 2007 | RCA Cable Modem DCM315R (11603540)
Zoom 5241 Modem Logo
145 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
