Cant see paper jam but when I try to copy I get paper jam message
Cant see any block in feeder tray, when I try to copy the paper is puled two inches and then stops and paper jam warning is issued
  • 97 Answers
The paper sensor flag is most probably jammed. This will require you to take it to yor closest repair centre. Ths uually happens when you had a paper jem and pilled the paper out in the wrong direction.
Posted on May 20, 2009
Paper jam, what to do
Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Oct 12, 2013 | Embassy Intek Tx40b 4 Sheet Countertop...
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Shows out of paper. Says paper jam. Open door . Clear carriage. Press ok. Cannot solve problem!!! 75 years old with 1st computer!
Out of paper
Cause: There is not enough paper in the input tray.
Solution: If the HP All-in-One is out of paper or there are only a few sheets
remaining, load more paper in the input tray. If there is paper in the input tray, remove
the paper, tap the stack of paper against a flat surface, and reload the paper into the
input tray. To continue your print job, press OK on the control panel of the HP All-in-
One.
Cause: The rear door is off the HP All-in-One.
Solution: If you removed the rear door to clear a paper jam, replace it.
rear door.
Paper can also jam in the automatic document feeder. Several common actions can
cause paper to jam the automatic document feeder:
• Placing too much paper in the document feeder tray. For information on the maximum
number of sheets allowed in the automatic document feeder, see Technical
information.
• Using paper that is too thick or too thin for the HP All-in-One.
• Trying to add paper to the document feeder tray while the HP All-in-One is feeding
pages.
To clear a paper jam from the rear door
1. Press in the tab on the left side of the rear door to release the door. Remove the door
by pulling it away from the HP All-in-One.
CAUTION: Trying to clear a paper jam from the front of the HP All-in-One can
damage the print mechanism. Always access and clear paper jams through the
rear door.
Paper specifications
This section contains information about paper tray capacities, paper sizes, and print margin
specifications.
• Paper tray capacities
• Paper sizes
• Print margin specifications
Type Paper weight Input tray1 Output tray2 Document
feeder tray
Plain paper 16 to 24 lb. (60 to
90 gsm)
up to 100
(20 lb. paper)
up to 50
(20 lb. paper)
up to 35
Legal paper 20 to 24 lb. (75 to
90 gsm)
up to 100
(20 lb. paper)
up to 50
(20 lb. paper)
up to 20
Cards up to 110 lb.
index (200 gsm)
40 10 N/A
Envelopes 20 to 24 lb. (75 to
90 gsm)
15 10 N/A
Transparency film N/A 25 25 or fewer N/A
Labels N/A 20 20 N/A
4 x 6 inch photo
paper
up to 145 lb. (236
gsm)
30 10 N/A
8.5 x 11 inch photo
paper
N/A 40 20 N/A
1 Maximum capacity.
2 Output tray capacity is affected by the type of paper and the amount of ink you are using.
HP recommends emptying the output tray frequently.
Paper sizes
Type Size
Paper Letter: 216 x 280 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Chapter 15
266 Technical information
Type Size
Legal: 216 x 356 mm (8.5 x 14 inches)
Envelopes U.S. #10: 105 x 241 mm (4.125 x 9.5 inches)
U.S. #9: 98 x 225 mm (3.9 x 8.9 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches)
Transparency film Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Premium photo paper 102 x 152 mm (4 x 6 inches)
A4: 210 x 297 mm
Cards A6: 105 x 148.5 mm
Index card: 76 x 127 mm (3 x 5 inches)
Index card: 101 x 152 mm (4 x 6 inches)
Labels Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm
Custom 102 x 152 mm up to 216 x 356 mm (4 x 6 inches up to 8.5 x 14
inches)
Top (leading edge) Bottom (trailing
edge)
Left and Right
margins
U.S. Letter
U.S. Legal
A4
Photo media
1.8 mm (0.07 inches) 2 mm (0.12 inches) 2 mm (0.12 inches)
U.S. Executive
B5
A5
Cards
1.8 mm (0.07 inches) 6 mm (0.24 inches) 2 mm (0.12 inches)
Envelopes 16.5 mm (0.65
inches)
16.5 mm (0.66
inches)
3.3 mm (0.13 inches)
Print specifications
• Resolution: 1200 x 1200 dpi black, 4800 optimized dpi color or 6 ink
• Method: drop-on-demand thermal inkjet
• Language: Lightweight Imaging Device Interface Language (LIDIL)
• Print speed varies according to the complexity of the document
(continued)
Print specifications 267
Copy specifications
• Digital image processing
• Up to 100 copies from original (varies by model)
• Digital zoom: from 25 to 400% (varies by model)
• Fit to page, pre-scan
• Copy speeds vary according to the complexity of the document
Mode Type Scan resolution
(dpi)1
Best Black up to 600 x 1200
Color up to 600 x 1200
Normal Black up to 300 x 300
Color up to 300 x 300
Fast Black up to 300 x 300
Try clearing all paper from all carriages (Top,Rear, Front, etc. then reinserting proper amounts. Even the smallest piece of paper can cause a jam. Here is a user manual in case you don't have one you can get it here: http://h10032.www1.hp.com/ctg/Manual/c00844812.pdf
This is a PDF and it is searchable and easy to navigate (Red lettering will take you to that section), so you will need Adobe Acrobat Reader (if you don't already have it you can get free here:
http://get.adobe.com/reader/
Also, once you have done all you can turn the printer off for a moment then turn it back on.
Hope this helps. Good luck
If this helps you resolve your problem, please
consider giving me a good rating and a quick thanks
or good job.It will help me as well Thank you.
Oct 26, 2010 | HP Officejet J5780 All-In-One InkJet...
Error message says"out of paper" when paper tray is fully loaded
check and make sure that the paper is in near the rollers enough that it senses the paper and picks it up. try lightly pushing the paper down toward the rollers as it is suppose to pull one sheet through the feeder. hopefully, you didnt pull too hard on getting the 'jammed' paper out that it may have caused a misalignment in the feeder. try assisting the paper, that usually fixes it. hope this helps!
Aug 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
Paper jam error message but there is no jam
usual problem is a paper sensor (most likely a small lever) has gotten stuck.. find the paper sensors and reposition them
Jun 10, 2009 | HP J4680 Office Jet All-In-One Printer
Hi I get this 250.07 paper jam check mp feeder on Lexmark t644
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Lexmark T644 Laser Printer
Paper Jamming when trying to copy or print
please check after you load paper on the paper tray and push it into the machine, should hear a click sound, if you don't hear that sound, that means you need to buy a new printer and that's no way to fix.
If you are able to hear a click, then please try to clean up your printer and check all paper loading rolls. if so, please replace it.
May 21, 2009 | Brother MFC 7420 All-In-One Laser Printer
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
169 people viewed this question
jasbo
jasbo
