Question about HTC BH M500 Bluetooth Mono Headset
HTC HEADSET WILL NOT CHARGE - HTC BH M500 Bluetooth Mono Headset
Just brought a HTC wildfire and I cant find bluetooth to turn it on .
Bell;
Important:
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so HTC Wildfire S can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press howtoimage.aspx?id=106492, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. HTC Wildfire S will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. HTC Wildfire S then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to HTC Wildfire S, the Bluetooth connected icon howtoimage.aspx?id=106796 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Mar 28, 2012 | HTC Wildfire Cell Phone
I have htc thunderbolt when i scan it wont find my bluetooth im wondering if there compatible?
Here is a solution that might work on your HTC Thundermug. The User's Guide indicates "activate bluetooth pairing mode by pressing the Power button". It should indicate to press and hold the power button. Pressing and holding resulted in the headset being recognized within 5 seconds by the HTC Thunderbolt. This is a problem with the User's Guide.
How to Pair the Plantronics 510 Headset
Good Luck from Headsets Direct!
Jun 27, 2011 | Plantronics 510 Voyager Headset - PLN-510...
I own a htc f3188 it is not recognising bluetooth head set how to get rid of this problem ????????
if the mobile htc phone and headset both are yours, you probably have their respective passwords, for other devices to read data (messages and pictures) on them. Check that both devices have bluetooth swiched on, then check the headset is not set to 'hidden' and that your htc is able to recognize other devices in the room/area. Check that the headset is sufficiently close to the htc (10 metres or less typically)and there is no physical obtruction between them that would cause a field disturbance
Dec 27, 2010 | Computers & Internet
Battery goes empty after full charge
Hi,when a battery goes empty after fully charged, means the cell of the battery is weak and can power on the phone for too long.
All you need to do is to replace the battery with another one,charge for about 6 hours before use and every thing will work fine.
Oct 05, 2010 | HTC BH M300 Bluetooth Mono Headset (UK...
Not pairing with HTC touch and bluetooth headset
I got jabra bluetooth which is not getting connected with my HTC touch mobile.It is not getting detected.
Oct 07, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Bluetooth Handsfree headset not clear.
You can tweak the bluetooth to give best results from the bluetooth option. But by doing this your battery charge will fireup very fast... :-)
Jul 11, 2009 | HTC Touch Viva Cell Phone
Htc p3450 not able to connect to nokia bh 201
Even my windows mobile cannot connect to my nokia headset.
So, buy a blue tooth headset for your pocket pc.
Oct 25, 2008 | HTC Touch P3450 Smartphone
HTC BH M500 Bluetooth Mono Headset Logo
Top HTC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a HTC Audio Player and Recorder Expert? Answer questions, earn points and help others
