Question about Pioneer VSX-917V-K Receiver
Pioneer vsx-917v wont exit standby mode, blue stand-by flashing. Disconected it from all sources and unplugged. No heat problems.
The amplifier stays in stand-by after being plugged in and will not turn on. The amplifier is not hot or overheating at all and has been disconnected from all sources and unplugged/replugged. Halp please.
5 Suggested Answers
SOURCE: Standby/ON keps blinking...Pioneer VSX-D812
JUST PRESS ADVANCED SURROUND & ENTER FOR LIKE 3 SECONDS.. THAT WILL RESET THE SYSTEM CHIP INSIDE.. :)
Posted on Apr 19, 2009
dragster301
  • 12 Answers
SOURCE: Pioneer VSX-918V-K Standby Light Flashes but will not turn on.
unplug it and press the power buton and then hold the power button, and while your holding the power button, plug it back in
hope it worked!!!
Posted on Jul 31, 2009
caroldon
  • 17130 Answers
SOURCE: My pioneer vsx-519V-k amp won't turn on. Just
Have you checked within the set, the fuse and if the standby circuit is working. thre could be a failure of this sub votage which is required for the switch on of the main power. If you do not have any standby indication you must check this section, however if you arre getting the standby you would have a failed output or a shorting that is triggering the error amp to swtich off. If you are familiar with the circuits you can check but I would suggest that since you will need more experience to look into the main board for tracing the fault. In such case check for the service centre nearest to the place you are in using a google search for Pioneer - Audio systems- sevice. Helpful I hope. Good day.
Posted on Jul 06, 2010
dunnbiker
  • 8546 Answers
SOURCE: My pioneer vsx 815 amplifier has a flashing blue
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
Resetting the main unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
OK? shows in the display.
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Posted on Mar 04, 2011
Pioneer vsx c301
Can you explain a bit more? Generally speaking when this kind of component shows that behavior means that is stuck in protect mode because it has an internal fault, and furthermore in the power amp output section.
Sep 20, 2013 | Audio Players & Recorders
Pioneer vsx 915 blue light flashing
Time for a repair shop to look, clearly the amp is down, it has failed. Have a qualified tech look at and get a repair estimate.
Dec 15, 2012 | Pioneer VSX-915 Receiver
I have VSX-505S amp.Now standby LED lits but when i press power on button it wont turn on.So i removed it and checked the stand by voltages and other things but couldnt find a problem.What will be the...
Sounds like the amp has an internal fault,most likely in the power amp/driver stage.If you have a manual and know how to repair amplifiers you could do it,otherwise it is a job for a technician.
Jun 18, 2011 | Pioneer VSX-505S Receiver
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Sir, i have an pioneervsx 917V-s , for
The user manual is available from here http://www.pioneer.eu/uk/support/manuals/VSX-917V-S/index.html
Not sure which settings you want to change
Mar 31, 2010 | Pioneer VSX-917V-K Receiver
hope it worked!!!
Jul 30, 2009 | Pioneer Audio Players & Recorders
Pioneer amp
maybe your relay is not function.
Sep 21, 2008 | Pioneer Audio Players & Recorders
Bose 901 connection to Pioneer VSX-917v Receiver
any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
mark
Dec 28, 2007 | Bose 901 VI Main / Stereo Speaker
Pioneer VSX-917V-K Receiver Logo
61 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
