Question about Reebok Vista Treadmill - RBTL13305
Replace drive belt
How to fit
How to change drive belt
  1. Step 1 - Loosen tension and remove belt. Locate the adjustment fastener and loosen it. ...
  2. Step 2 - Inspect drive and drive pulleys. Check the drive and pulley wheels. ...
  3. Step 3 - Select correct replacement belt. ...
  4. Step 4 - Install V-belt. ...
  5. Step 5 - Correctly tension new belt. ...
  6. Step 6 - Start the engine.
Mar 24, 2016 | Huskee Tractor Replacement Riding Lawn...
Tip
95Xi Crosstrainer Drive Belt Replacement
Drive Belt Replacement Video for LifeFitness 95Xi Crosstrainer Elliptical
Tools needed:
  • Philips Screwdriver
  • T25 Driver
  • T50 Driver
  • 2MM Allen Wrench
  • 5/32" Allen Wrench
  1. Remove the main shrouds as seen in the main shroud removal video
  2. Remove the left outer link cover as seen in the Outer Link Cover removal video
  3. Remove the left pedal lever assembly as seen in Sportsmith's Pedal Lever replacement video
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Walk the drive belt off the pulley and remove it from the unit
  6. Install the new belt around the crossover shaft first and then walk it onto the pulley
  7. Replace the remaining parts in reverse order
LifeFitness 95Xi Drive Belt Video How To Replace
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
Zanussi fls 1284 - how is it possible to make the right belt fit - I have tried and tried - it will not fit. What can I do?
It is elastic drive belt 1196 J5 which means that 1196 mm is the working length based on the belt mounted on the pulleys. "J" and "H" means shape of the drive belt and finally number after word (J5) means number of teeth (could be: 4,5,6,8) .The length marked on the drive belt (1196,1217,1280 etc.) is the working length based on the belt mounted on the pulleys. For a given working length, the belts - which consist of different materials - have a different degree of elasticity. This means that, when not fitted to the appliance, their lengths may be different. It is normal that the length of a plastic belt not fitted to the pulleys is three or four centimeters greater than that of a rubber belt. Also, both types of elastic drive belt are shorter than the working length and therefore it is a little more difficult to replace but not so much that you have to lossen motor.
Please follow this link:
https://www.youtube.com/watch?v=yC21q2-eAfI
Dado
Sep 13, 2015 | Zanussi Washing Machines
Why does the belt keep coming off my Crazy Fitness Massager? I bought this machine second hand so I'm not sure if the belt is the original. It has a Jiali 230J on it. The belt doesn't seem wide enough? Can...
Your pulleys may be misaligned (shafts must also be perfectly parallel) or the belt is possibly too long. Drive belts for fitness equipment here: http://store.beltpalace.com/fitnessbelts.html
They have a phone number to call on their website, too.
Ribbed Fitness Drive Belts for Elliptical Machines PJ Metric and...
Aug 09, 2014 | Sunny Health & Fitness Crazy Fit Massage
Kia sedona instructions to replace serpintene belt
Hi, Here is the procedure for a 2002 KIA Sedona 2.9, Engine code KJ. I I can not guarantee the followingprocedure is exactly the same as your car.
Warnings and recommendations Unless otherwise advised by the manufacturer, the following procedures are recommended: Always fit a new timing belt after removal Check the tensioner and idler pulleys; renew if necessary Never turn the engine in the direction opposite to that of normal operation Check the belt(s) for cracks, fraying, wear and oil contamination Note: The engine must be cold before timing belt adjustment Note: Avoid bending, torsion or traction General Before disconnecting the battery cable, check the audio system security code kj_t_dba_uk_6.jpg
Always check the timing marks before timing belt removal Removal Disconnect the battery Remove the radiator upper hose Remove the fuel filter unit Note: Do not disconnect the hoses carniv_j3tci_t_dba_uk_3.gif
Remove the bracket Remove the right front wheel Remove the air-conditioning drive belt Remove the ancillary drive belt Remove the ancillary drive belt tensioner Remove the coolant pump pulley Remove the crankshaft pulley Remove the timing cover(s) kj_t_dba_uk_6.jpg
Remove the tensioner Remove the timing belt Check the gearwheels, tensioner and idler pulley(s) for damage and wear Renew if necessary Installation kj_t_dba_uk_6.jpg
Align the marks on the tensioner Tighten the tensioner (23.5 Nm) Rotate the engine 2 rotations by hand kj_t_dba_uk_6.jpg
Check the tensioner Repeat the procedure if required Refit the timing covers Refit the crankshaft pulley (373 - 392 Nm) Refit the coolant pump pulley (17.6 - 28.4 Nm) Fit the ancillary drive belt tensioner Fit the ancillary drive belt Refit the air-conditioning drive belt Refit the front right wheel (88 - 108) kj_t_dba_uk_4.gif
Fit the bracket (36.2 - 53.9 Nm) Refit the engine mount carniv_j3tci_t_dba_uk_3.gif
Refit the fuel filter unit Refit the radiator hose(s) Refill the cooling system Check for leaks Reconnect the battery earth cable Torque settings Tensioner: (23.5 Nm) Timing covers (6.9 - 9.8 Nm) Coolant pump pulley: (17.6 - 28.4 Nm) Special tools Special tools are not required
Jan 06, 2013 | 2004 Kia Sedona
Drive belt requires to be replaced. Have got correct one, however, seems too tight to fit round wheel and pulley. Access is only through top of machine so this does not help. Is there a tool or technique...
Hello
The motor has a tension bolt that you need to loosen befor you can fit the belt. once the belt is fitted you can retention the motor.
Thanks
Jun 11, 2011 | Washing Machines
The drive belt came of off the pulleys and it is hard to stear the weel
It is virtually impossible to steer a vehicle which has hydraulic steering assistance, when the drive belt is removed. Unless one has arms like Superman!
Unfortunately, as that is your position, I am afraid that you will have to have a replacement drive belt fitted to enable power assistance to the steering to be restored. It might be of great benefit for you to ascertain why the drive belt came off the drive pulley, before having the replacement belt fitted. if there is a problem with the pulleys, it would be wise to have it rectified before fittting a replacement belt.
Jan 09, 2011 | 1997 Dodge Caravan
How do I loosen the tensioner to replace the serpentine belt on a 2004 Honda Accord?
First, note how the drive belt is routed, then use a wrench on the tensioner pulley center bolt and turn the tensioner clockwise (four cylinder engine) or counterclockwise (six cylinder engine) to release the drive belt tension. Remove the drive belt from the tensioner and relax the tensioner. Fit the new belt on the other pulleys, then turn the tensioner again and fit the new belt over the tensioner.
The picture is from a different model, but it is similar to what you are working with.
Hope this is helpful to you.
Dec 19, 2009 | 2004 Honda Accord
How to replace the belt on a whirlpool duet washer
To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and remove the rear panel.
2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, please let me know. I hope this helps you.
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Reebok Vista Treadmill - RBTL13305 Logo
23 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
