Question about Bushnell Sportsman 3-9x40 Rifle Scope 723940 M Matte In Box 3x9x40
How to adjust scope
How to adjust for 50 yd range
2 Suggested Answers
magoo23
  • 22 Answers
SOURCE: sighting in red dot shotgun scope
Load your gun up and when you can shoot it, aim with your new glass(Scope) and lay out a group of three slugs, not buckshot, (i'm assuming your shooting a shotgun). Then use some trial and error to tighten your dot to your grouping. I don't blame you for the confusion, but normally, most scopes set up for this adjustment pattern are moving your target according to the knobs, not your crosshairs or dot. Another option you have is to buy a laser bore sighter. then you can play with adjusting your scope for in the field or wherever with much more comfort when you need to. You can find them online at walmart or almost any sporting goods store these days, yes they save ammo and yeas they save time, but i still shoot to make sure i'm dead on after using mine.
Posted on May 06, 2008
FDD Y-E Data YD-380B Repair RFQ
I have a YE Data YD-380B disk drive. I/O error is appeared when it try to read floppy. How can I solve this problem
thanks
mehrdad
Jun 12, 2013 | Ye Data - yd-380b - Yd-380b 1.2mb 5.25...
How do you make adjustments, towards the shot or towards center of the target?
You move the cross hairs to the shot. Set up your gun on a bench and start by firing at a target out at about 15 yards. Once you are "on paper" set your cross hairs on the center and fire a 3 shot group Adjust the scope to the group. if the group is down 3 inch and left 4 inch. Adjust your scope accordingly. Then Fire another 3 shot group, until you are shooting center. Every time you adjust your scope tap the barrel of the scope with a screwdriver handle to keep the cross hairs from sticking. Once on at 15 yards move out to your max range and adjust to that.
Mar 19, 2011 | Brunton 2x20mm NRA Sports Optics Rifle...
How to set scope up by yd lines in scope,
dont even trust them,,,,if you use them with one make of ammo they will be off with another make of ammo,,,,,so test fire it,,
Nov 21, 2010 | Pentax Gameseeker Rifle Scope Warranty...
On the adjustment turrets, after loosening the set screws, how do you get it to go down so the yardage lines up?
after you sight the rifle in at say 100 yd. lift the turret and line up the 100 yard mark on the turret to the mark, then push the turret down onto the scope and set the screw. some times the turret takes a lot of pressure to push back on.
Mar 29, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
When adjusting for a couple of inches, the next shot is a foot off. It seems to wander all over the target.
! click is 1 inch @ 100 yards, provided you have the correct scope for the rifle.
If you are sighting in a .22 LR 40 grain match velocity bullet for 100 yards, the mid range trajectory (50 Yards) is 6" higher. The bullet has a 6" arc half way to your target. If you are sighting in a .270 with 150 grain blunt tail bullets for 250 yards, the mid range trajectory is .4 higher. It only has 4/10" arc half way.
You most match the scope to the gun, and the 1 click= 1 inch rule will apply. Otherwise, it's lock it into a righd mount, fire it and adjust the scope accordingly. If you want to change the range on the scope, it will be guesswork.
I use a Bushnell Banner 3-9X40 with BDC. If you have BDC, make sure you have the correct distance ring in for the caliber.. It will make all the difference in the world.
Oct 27, 2009 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
Tasco 6x24x42 cosistancey issues afield.
It has to settle in to the mounts an the mounts to the gun. You take a screw driver and tap on the scope as you adjust it. Tap with the handle and just tap it not bang. every time you make an adjustment tap it. The 222 does not give a great kick so you do not get the settling from that, you have to cause it by taping the scope with the screw driver.
Jul 19, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
Is this going make diffirents in at the Range or on the hunt?
Your problem is in the bases/rings. Remove the scope from the rings. Lay a straight edge in the bottom of the rings. The straight edge should touch both rings equally. If i understand you right, you have run out of adjustment up. If so, there will be a gap on the front ring. Verify that you have the correct bases for your rifle first of all. Then, depending on the rifle, you may be able to swap the front and rear bases/rings and correct the problem. Check alignment as above. NOTE: After rings are corrected, re-center scope elevation. Turn elevation screw on scope one way untill it stops. Count the clicks as you turn back to the opposite direction. Devide the clicks by two. Turn back the other way by that number. Your scope is now centered. Test fire at 25 yards. When close to zero, move back to 100 yards and fine tune.
Jul 04, 2009 | Bushnell Sportsman 3-9 x 32 Rifle Scope w/...
Adjusting Range on Redfield Scope
There should be a set screw or screw that you can loosen to make that adjustment. Once you have it where you like it, just tighten it back up and enjoy you ability to make those quick adjustments when needed.
Mar 29, 2009 | Optics
Sirs Shooting 25-06 dead on @ 100 yds., shot @ 200 yds hit 12" high, shoot again and the second bullet hit right at the first hole. Shooting H&R Handy Rifle, Hornady 117 gr. bullets Please advise to what...
sounds like it could be the scope more than any thing but shoot at 100 yd 5 shot group and see if it groups if if shots dance around on target make shure your mounts are tight there is time that companys send screws for the mounts that are to long for the holes that are taped in the gun the mount mite feel tight but could have play yet witch make your gun not shoot well you could also try setting the scope on 4 power shoot a shot at 50 yards then crank it up to 9 power shoot a shot if bullet impact moves it is the scope hope i helped ya out and good luck
Feb 24, 2009 | Optics
Bushnell Sportsman 3-9x40 Rifle Scope 723940 M Matte In Box 3x9x40 Logo
794 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
