I have a Dimplex MDA20 electric blower heater. For some reason it will only blow out cold air so I'm trying to find replacement parts for it.
I think I require a new heating element for my Dimplex MDA20 blower heater as it will only blow out cold air at the moment.
buzzwood
  • 65 Answers
SOURCE: Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
Posted on Jan 21, 2009
  • 10 Answers
SOURCE: oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Posted on Mar 16, 2009
SOURCE: Chicagao electric fireplace heater doesn't work
MY HEATER NOT WORKING,BLOWER AND LIGHT COME ON NO HEAT
Posted on Sep 20, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Posted on Nov 03, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: my heater blows cold air. any ideas?
Your unit has a diagnostic light on the circuit board. You need to look thru a small viewing port to see it. Once you count the number of b links, remove the lower panel and look at the wiring diagram for an error code chart. Then read the following to give you some ideas what to do.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Dec 01, 2009
Fan heater blower on dimplex cadogan CGN 20 not working properly0 optimyst electric stove
Take it out and see if the fan wil turn by hand. It may have somethng obstructing it. The clicking is the motor overload. It wil burn out if it continues to keep clicking.
www.dimplex.co.uk/assets/.../Cadogan_Stove_Instructions_Issue_2.pdf
Jun 29, 2014 | Heating & Cooling
Dimplex problems
heater coils normally glow orange when it works
Anyone know where I can buy part number 2800090200RP besides Dimplex? it is a small on/ off switch for a electric dimplex small stove model number 6901050100
Some hardware stores, electrical supply stores, radio shack, are a few places I would think of trying. Take old one with you to make sure same amperage/voltage rating.
Sep 15, 2011 | Dimplex Compact Electric Flame Stove...
The fireplace blower does not work therefore there is no or very little heat from my dimplex elect fireplace---thanks
This is a constant problem for ALL electric fireplaces with heaters. Either the Owners Manual fails to the manufacturer not telling you that the heating elements need routine cleaning, because they are sucking in household air to heat it and send it back out, So whatever is float in your household air (dust, lint & pet hair) near the floor goes into it, clogs it up and causes the heating element to overheat and fail. Or customers who have purchased these units don't read the Owners Manual.
These units, no matter who the manufacturer is were not designed to heat for long periods of time. In fact the heater element doesn't produce much more heat that a blow drier on high heat.
The heater and the blower and are in the lower compartment of the firebox. If you can access it, you can clean it with a shop vac and a brush attachment on the end of the hose. Be sure to unplug the fireplace from the wall outlet before attempting this. If cleaning it doesn't help, the blower motor will have to be replaced. You can order one from Dimplex USA.
Feb 06, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
My Dimplex DFB 4047 won't get very hot
This is an on going problem with electric fireplace/stove type heaters of all types. Not just Dimplex.
They are not designed to run for long periods of time and the heat output is not much more than a blower dryer. In any event, they take in cool air, heat it and send it back out. Over time, the heating element becomes clogged with dust, lint and/or pet air. So, they have to work harder to produce a sufficient amount of heat. Cleaning the heating element with a vacuum that has a hose and brush attachment may help. The heating element and blower are under the stove. See your Owners Manual on how to access it. Be sure to unplug the stove before trying to service/clean it.
Feb 05, 2011 | Dimplex Compact Electric Flame Stove...
Front Blower
ok, missed the part about the rear ac working, the part that causes this is called the air temperature control blend door actuator motor, it is an electric motor driven gear drive that moves the plastic door inside the air ducking to mix or shut off the hot or cold air from the ac evaporator core or the heater core, you will need to replace it.
Sep 03, 2009 | 2002 Dodge Durango
Heater fan stop working after a couple of muinutes
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email cairoeichard@gmail.com
Jan 02, 2009 | Dimplex Compact Electric Flame Stove...
My air heater won't turn on it's a Dimplex DFB6016. What can I do?
call Dimplex : 1-800-668-6663 Ext: 358 These folks can solve your problem and send you replacement parts.
Dec 13, 2008 | Dimplex Compact Electric Flame Stove...
ELECTRIC FIREPLACE ONLY 1+ YEARS OLD HEAT STOPPED WORKING ONLY?
The heater will not work if either the thermostat or blower are not working. (or the heater element is bad). Most of the time with these electric heaters, it's the thermostat.
http://extranet.dimplex.com/files/domain4103//DS5598%20DS5603%20DS5804%20PARTS%20&%20SERVICE%20MANUAL%20REV00.pdf
page 6 has a list of the parts
Feb 02, 2008 | Dimplex DS5598 Mid-Size Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
