Hi, you can download the driver for the HVR-1600 from
HERE
(53MB FIle)
Step 1 - Extract the Installer
Download the file to a suitable location on your computer, then extract it . Windows has built in support for zip files, if you right click on the file and select 'extract all' a wizard will guide you through extracting the directory.
Step 2 - Remove the previous software version (if necessary)
If you had previously installed the WinTV-PVR-1600 in your PC, browse to the folder you just extracted to (e.g. through My Computer) and locate a file called
hcwclear.exe
Run
HCWCLEAR.EXE and choose the options
Remove All WinTV Drivers and Applications (Total Removal) and
Search All .INF Files for Conflicting Hardware.
Note: wait until the black box has disappeared of its own accord before proceeding.
Step 3 - Reboot
Shutdown and reboot your PC.
IMPORTANT! Once rebooted, please do not cancel any 'Found new hardware' wizards. Also ensure that the original driver CD is NOT in the CD drive.
Step 4 - New Driver Installation
After Windows reboots, you will see some
New Hardware Found prompts. For each one, please choose the following options:
4A) On the first page, select '
No, not this time' and click
Next.
4B) On the next page, select '
Install from a list or specific location (Advanced)' and click
Next.
4C) On the next page you will be asked '
Please choose your search and installation options'. Select '
Search for driver in these locations' and then specify the extracted folder (the folder you extracted in step 1).
Note: Specifiy the 'Driver' subdirectory if Windows cannot find the driver file.
Note: You can also click the
Browse button and browse for the directlry created in Step 1.
4D) Keep clicking
Next for the rest of the steps then
Finish to end the Hardware Installation Wizard
Depending on the model WinTV board, you may see several
New Hardware Found wizards. Follow the same steps for each.
Step 5 - Run Setup.exe
Run
Setup.exe from the extracted folder (from Step 1). You will be presented with a list of things to install, leave all the default settings and click
Install.
Once the installation is complete, all drivers will be installed and you should have a WinTV2000 icon on your desktop.
