Bush a127ldw washing machine does not pump out water
5 Suggested Answers
SOURCE: washer not spining
I took the bottom panel off the washer. I don't know what i'm looking for?? Help!! The washer won't spin. the belt and motor are ok..
Posted on Sep 14, 2008
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
  • 156 Answers
SOURCE: My washing machine is flashing
sounds like either the pump is blocked or broken.
bring machine forward so that you can tilt it back so as to be able to undo filter cover.
Be aware, lots (and i mean lots) of water will exit so a) have a big bowl and b) only undo filter cover a little so can retighten quickly.
Repeat until all water gone, remove cover completely and clean pump and filter area.
Refit cover, put machine back on floor, put on spin cycle and if it was a blockage, machine should empty. If not, new pump time I'm afraid
Posted on Dec 08, 2010
SOURCE: Servis 7kg 1500 AA - bush's and motor, ok and
Hi it's a temperature or water level issue i think, if you have the temperature at 30' it should be ok, as it did it on mine and i noticed that if i turned the temp down to 30' it would work or put extra water it via the dispenser then it would work in the higher temp settings.
Posted on Feb 02, 2013
Error message E03 coming up on my Bush A146CDB Washing Machine. Any help much appreciated.
fault code 3 usually means:
Not drained in time allowed - washing machine fails to drain water
Check that filter is not blocked or obstructed
Check drain hose is clear of any blockage or obstruction
Those above are checkable by yourself and the ones below need to be checked by a professional.
Check wiring to drain pump
Check drain pump is not defective
Check level sensor or switch
Check wiring to level sensor
All the best
Aug 17, 2016 | Washing Machines
How do i get my filter out of my bush a127ldw washing machine got E03 error am working my way through your list but cant get filter out
Water inlet filters
On the tap part of your machine's water inlet
hose and at the ends of water inlet valves, there
are filters to prevent entrance of the dirt and
foreign materials in the water to the machine. If
the machine is unable to receive sufficient water
although your water tap is fully opened, these
filters should be cleaned.
x Remove the water inlet hose.
x Remove the filters found on the water inlet
valves by using a pincer and wash thoroughly
with a brush. (1)
x Clean the filters of the water inlet hoses
located on the tap side by removing manually
together with the seal. (2)
x After you clean the filters, you can fit them
the same way as you have removed them.
Pump filter
The pump filter system elongates the life of your
pump, which is used to drain the dirty water. It
prevents lint to enter the pump. Cleaning of your
pump filter in every 2-3 months is
recommended. To clean your pump filter:
x Open the kickplate's cover, by pulling the
handle. (2-A & 3-A)
x Before opening the filter cover,place a cup in
front of the filter cover to prevent flow of the
remaining water in the machine.
x Loosen the filter cover by rotating it counter
clockwise and drain the water. (4-A)
x Remove the foreign materials from the filter.
x Check for the rotation of the pump manually.
x After you have cleaned the pump, fit the filter
cover by rotating clockwise.
x Put the kickplate cover into place.
x Do not forget that if you do not fit in the filter
cover properly, it will leak water.
Jan 21, 2013 | Washing Machines
relay is stacked so you start the machine off position power on the wash butten you will check this method
Sep 13, 2011 | Washing Machines
My washing machine is flashing err2 and is not spinning. I have lots of clothes locked in a machine full of water! Help! wm-1460tve bush washing machine
Dec 08, 2010 | Washing Machines
What does error 5 mean on the bush wm-1260tve washing machine?
Hi.
Error 5 means that there is a water inlet problem.
Move the appliance, ensure that the water hose is not kinked or blocked, and check filter in water hose if installed.
Check connected faucet and water pressure.
If the inlet hose and pressure is OK, then the inlet valve and water pressure switch must be tested as one of the two parts is likely giving the error.
Regards.
Ginko.
Sep 20, 2010 | Washing Machines
My whirlpool wtw5500sq0 leaks water when washing
There can be many causes for this leak, and where it leaks helps diagnose what to fix. Most commonly the water pump leaks from its seal and bushing over time since it spins whenever the motor is engaged. The reason it never spins water out until the spin cycle engages is because it is turning in the opposite direction as flow to prevent water running out as you wash, You way also have a separation of the washtubs water ring, or a crack near the top, since the leak only happens during wash time.
Mar 18, 2010 | Washing Machines
Washer not spining
i think there is problem in your water outlet pump problem first of all you check water is come out or not from machine
Feb 11, 2008 | GE Profile Prodigy WPSE4200A
Hotpoint WD61
1, your pump may be blocked by fluff coins and other debris.
2. more likely bushes worn on the main motor not giving enough umphhh (loverly word) to go through a complete spin....Bushes easily replacable. Job start to finish with parts on hand a machine mechanic 10-15mins top Diy er like me an hour allways have trouble finding the right spanner... Good luck.
Jan 06, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
