Question about Hampton Bay 52 In. White Huntington III Ceiling Fan
How do i change the bulb in my blyss benden ceiling fan?
I think this website about ceiling fans with lights maybe help you. Good luck
Posted on Sep 21, 2016
5 Suggested Answers
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
patrick_a_t_
  • 3 Answers
SOURCE: Changing light bulb in ceiling fan
At the top of the pull chain there is a metal piece; this is threaded on a bolt. Unscrew the metal piece and lower the globe to expose the bulbs then remove and replace the bulb(s). I recommend flourescents as they are more economical, run cooler and last linger than incandescents (regular bulbs).
Posted on May 17, 2009
  • 351 Answers
SOURCE: Ceiling fan working, but lights on fan not
If there is a remote then the problem may be in that device ... You should check the wiring in the canopy at the ceiling and make sure that the wiring connections are secure . check both the black and white wire connections.
Please vote !
Posted on Jun 04, 2010
davea9952
  • 1617 Answers
SOURCE: ceiling fan light
If you have a remote you probably need a new receiver.
Posted on Mar 31, 2013
Minks aire mojo ceiling fan light will not come on
Try changing the bulb. Make sure the bulb is touching the connector in the bulb socket.
Aug 15, 2014 | Minka Aire Ceiling Fan
Blyss benden fan how do I change the bulb
The glass globe covering the bulb just pulls off, but do not use any metal tools to lever it of or you'll break it.
Putting it back is very difficult. It just pushes back on but maybe put a little bit of soap on the lip to make it easier.
I learnt the hard way and gave it a thump with the palm of my hand and broke the globe. I cannot find a replacement anywhere. B & Q where I bought it where absolutely useless. They just gave me a factory address in China!
Good luck
Richard.
Nov 24, 2012 | Dryers
My hampton bay ceiling fan it a rounded light and I don't know how to get to the light bulb to change it?
ther are three small screws that need to be loosen, once these are loose, the globe will come off and you can now change the light bulbs
Oct 18, 2009 | Madison Avenue 04889 Hampton Bay Ceiling...
Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Sep 07, 2009 | Minka F603-WH Ceiling Fan
Question about light bulb problem in ceiling fan
Check wiring @ ceiling. Should b a black, white, green & red wire coming frm fan. Green is ground. Black & Red is power. White is neutral. Black provides power to fan, red provides lat power 4 lights. Remove light assembly, blue wire provides power. B sure 2 turn off power 2 fan b 4 working on it w/switch & breaker. Maybe lose wire connection or pinched wire grounding out. Fans require vibration proof bulbs regular bulb elements will break after short time use. Fan bulbs have larger filiments inside bulb.
Aug 23, 2009 | Aloha Housewares (93645) Ceiling Fan
May 17, 2009 | Hampton Bay 24002 Ceiling Fan
Bulbs burning out in Hampton Bay ceiling fan
I would suggest getting an electrician to check the current running through the wiring. I had installed a similar fan in my grandmother's house a couple of years ago and had the same problem. After a couple of months of constantly changing bulbs, I brought in an electrician to check the current and found that there was a short in the wire which kept causing just enough of a current surge to blow the bulbs.
Nov 29, 2008 | Hampton Bay 04345 Cruiser Ceiling Fan
Change light bulb
I have a fan just like that one to change a light bulb all you have to do is unscrew it from the fan itself and if that dosnt work then unscrew the plastic cover or unscrew a screw on the plastic cover
Dec 30, 2007 | Madison Avenue 04889 Hampton Bay Ceiling...
Hampton Bay 52 In. White Huntington III Ceiling Fan Logo
295 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
