Code for playsonic tv
I am looking for the band code to use a universal remote control with a playsonic tv
  • 3 more comments
  • ryanmccauley Oct 06, 2008
    I have a playsonic tv and am looking to hook up my sky remote to it
  • corein Oct 24, 2008
    i have a universal remote but no code for the playsonic 14" tv .
  • johnob5 Dec 12, 2008
    cannot find the playsonic code to put into sky remote
  • Anonymous Dec 25, 2008
    i ned dat code ANY 1 HELP ?
  • Anonymous Apr 22, 2009
    cant get code to programme remote control
5 Suggested Answers
  • 97 Answers
SOURCE: Universal Remote control code on Sharp 13H-M60
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 20, 2008
SOURCE: codes for universal tv remote control vivanco upr 250
Try here:
Posted on Oct 29, 2008
SOURCE: bush tv remote code
need codes for universal control bush
Posted on Apr 13, 2008
  • 8 Answers
SOURCE: Program codes for tv and satelite.
The manual
Posted on May 25, 2008
Need to program my phillips universal remote CL035A to my Sylvania TV
Look in the manual of your
Phillips universal remote CL035A for ther listing of TV codes, take notes of codes for Sylvania and input codes accordig to instructions of your manual.
If you can locate Sylamia, follow instrucions for unspecified device.
You don't have a manual?
How to Program Philips Remote Control Without the Codes eHow
Jun 19, 2015 | Sylvania Televison & Video
I need a setup manual for the hype 4-in-1 universal remote control along with codes to a sanyo lcd tv
Common set-up codes for Sanyo band TVs are; 0291,0299,0295,0297. Try these codes. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 07, 2013 | Universal Remote Control Televison & Video
I do not have the correct code for the playsonic tv.I am using BB-TV154 8 in 1 TV remote control.Please could you advise me on my problem.Thank you.
Try the last 3 or 4 digits of the TV's serial number. That worked for my ATD TV after all else failed.
Let us know if it worked or not, thanks.
Oct 08, 2010 | Televison & Video
I have a playsonic Tv and cant get my universal remote to work with it
first of all; is your tv model applied in the program of the universal remote? NO??? look for one that is.
yes..... but you did try all the codes and still not working?
try this with tv on:
- press and hold tv botton on remote for 3 sec until the red led light up
- then with a constant rate of each sec press off/on botton on remote. make sure to aim the remote at the set.
- at the moment the set goes off press enter. this should do the trick. NO GARANTEE....
succes and enjoy :)
Aug 23, 2010 | Televison & Video
No code for playsonic tv
If you have a Brookstone remote control this will work for you.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control, keep in mind when not trying to use this sequence with any other remote than a Brookstone you might have to have the unit on when doing this, then it will turn off when you have the right code. I would try the first option first.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
• To exit without storing the code, press BACK.
• The unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
Oct 31, 2009 | Televison & Video
Here are some sites that will have your codes and instructions on how to enter them:
  1. Universal TV Remote Control codes Universal remote control codes for all TV and VCR brands including: at&t, beery systems, bondwell, curtis mathis, dish network, ge, gemini, ... - 23k - Cached - Similar pages -
  2. Universal Remote Control Codes Universal Remote Control Codes for DVD, VCR, TV and Home Theaters System. - 7k - Cached - Similar pages -
  3. Philips Magnavox Universal Remote Code Philips Magnavox Universal Remote Code - Instructions on how to program your Philips Magnavox universal remote control. - 35k - Cached - Similar pages -
Apr 17, 2009 | Televison & Video
I want to tune a vcr to a playsonic tv. the vcr
I don't have the remote control with me, how can I do to put AV1, without remote? Its that possible?
Mar 14, 2009 | Televison & Video
Televison & Video Logo
1,965 people viewed this question
Top Televison & Video Experts
