My Hoover AL120 washer, will boil the water during a 40 degree cycle so steam comes out of the detergant drawer. I have changed the temp sensor at the back of the drum - the problem is still ongoing.
if the temp sensor is operating ok but the element doesnt switch off there may be a problem with the power board/timer just follow the wires back to find problem.
Was this helpful?
Yes
No
Popular Solutions for Hoover AL130 Front Load Washer
My hoover wdm 150 washer dryer will not dry. The drum spins as normal but no heat is generated. The...
(More)
My hoover wdm 150 washer dryer will not dry. The drum spins as normal but no heat is generated. The front reset button clicks when pressed after trying the dryer.
My hoover 6 express washer dryer has just started leaking from undearneath near the lint trap out...
(More)
My hoover 6 express washer dryer has just started leaking from undearneath near the lint trap out the front of the machine near the end of a wash cycle. Trap is clear, have ha dteh back off and all pipes seems well sealed and connected, it seems to leak from the solid plastic internal casing on the right hand side (as you look in from the back) and runs down the natural curve of the plastic dripping and forming a puddle that then leaks out the front underneath of the machine. Is there a way of fixing this problem , how do i get to it etc
error 2 has being cumming up on the screen some times but now it gets to the welcome screen and no...
(More)
error 2 has being cumming up on the screen some times but now it gets to the welcome screen and no progress also the express wash light and the select spin light are flashing and the time on the screen is also flashing
