Can't connect lg sound bar to blaupunkt tele
Optical cable does not fit into back of TV
SOURCE: optical output on tv through dvd home cinema out of sync
I just had the same problem. I returned it to currys and got an exchange because I thought there was somethink wrong with the surround sound itself. I have just tried , and left for ages as it goes out of sync gradually as you said ,the red/white cables (rca , i think it's called)and it works perfectely. You can find the wire for quite cheap just type it in google.
Posted on Oct 15, 2007
jsinex2421
  • 62 Answers
SOURCE: No surround sound when attaching hdmi to TV
Try running the optical TOSLINK cable from the TV to the receiver. If the TV doen't have a digital optical output, then try going into the menu on your cable box and setting the audio output to the digital optical out. Also check your TV menu and make sure NETCOMMAND is diabled. Some of your newer HDTV have Netcommand that allows the TV to control other devices through the HDMI cable.
Posted on Jan 10, 2009
SOURCE: connecting lg tv to two external speakers
Yes,
depending on how many speaker you intend to run will determine the type of amp you will need.  Set the output on the source unit to optical out.   Connect the optical cable to the amp.  Connect the speakers to amp.  turn them all on and select the iput of the source unit on the amp and enjoy.
good luck
chachig
Posted on Feb 11, 2009
cpt_cavman
  • 69 Answers
SOURCE: connecting external speakers with optical cable
Id say you DO NEED to adjust your TVs audio settings.
Posted on May 10, 2009
Up front, i copied this from another site, so kudos to the OP there if this works for anyone...
This same problem had been bugging me when I bought my LE37B650, everyone suggested adjusting the delay time on my AV amp but unfortunately mine does not have this function.
Anyway I finally fixed the problem using the following steps
Before you start make a note of your menu settings as you will have to reset them after this procedure
Turn off the TV then press Info -> Menu -> Mute in sequence then turn the TV back on again. This will get you into the secret Service Menu. Go straight to the AUDIO page of the menu. Don't be tempted to fiddle with things in service menu cos you can end up in a right old pickle!
In the AUDIO page you willl notice that there is a time delay set for the internal speakers of 100ms but for some reason this is not set for the external output so all you need do is dial in a 100ms delay there and that should sort the problem. Well it fixed it for me.
Note that as soon as you enter the service menu, all your other standard menu settings are lost and the screen will be set to dynamic for some reason so you have to go through and change everything back after you have done this.
Hope this Helps
Original link: http://www.hometheaterforum.com/forum/thread/280579/audio-delay-on-samsung-650-lcd-tv
This would suggest that you CAN fix the problem with an analog amp.
Also interested to see if a 2 year old thread is alive!
Posted on May 26, 2010
Just purchased Rico bos90. Put optical cable from my lg tv to the optical on the sound bar. No sound whatsoever
You may need to configure either the TV settings or the sound bar to use the optical connection. If both have HDMI connections, you might consider that connection method as an alternative.
Aug 03, 2016 | LG Televison & Video
How do i connect a LG sound bar to a sharp aquos
optical out of tv to sound bar. if not come of your cable box optical...
Sep 30, 2015 | LG Televison & Video
A LG soundbar to a Laurus TV I've fix a optical lead one end and jack plug on the other but it doesn't work
A fiber optic cable carries infrared light path only. It's a digital signal, you can only connect this to equipment that has an optic connection. Adapting it with any kind of analog jack just simply won't function.
laurus tv images Google Search
checking the Google images of the Digital module does not show a tos-link connection for the module.
Apr 17, 2015 | LG Televison & Video
I am trying to connect a lg sound bar to a blaupunkt TV. But it doesn't have a digital optical connection. Can I still connect it and how? Thank you
If you have a digital coax out, or vice versa, they make digital optical convertors. Try MCM Electronics.
Dec 12, 2014 | Televison & Video
I am trying to connect a LG sound bar to my Blaupunkt 50" TV. I havent got a digital optical connection on the TV. How can I connect the soundbar?
There should be audio output with your TV. Connect it with the Sound bar; using an AV cable. The cable might have three cores to connect, but you need to connect its Red and White pins. Leave the Yellow pin free; as it is meant to connect to Video. Electro help
The connection cable will look like this.
How to fit anb3530a lg soundbar to toshiba tv
trade your TV or Sound bar to something that is compatible. IE Make it work, No optical port find a sound bar that works with RCA, Make certin you have RCA audio outputs on your tv, if you want the sound bar than New TV
Jul 28, 2014 | Toshiba Televison & Video
LG sound bar connected to Pioneer TV by optical cable not working
1. if you have something else that you can test the optical wire on. do that first. dvd player etc... if the test item works, it's the sound bar (or a setting in the sound bar.)
2. check the audio settings on your t.v. make sure it's set to output to optical.
3. replace the wire.
if none of these solve the problem, the t.v.'s optical output may be bad.
May 08, 2014 | Pioneer PDP-4270HD 42 in. Plasma...
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
Wont retain audio settings
Try just using the optical cable alone. connecting the HDMI and the optical cables at the same time might be confusing the TV.
Mar 27, 2017 | LG 42LC2D 42 in. LCD HDTV
CANNOT GET SOUND FROM THE KLIPSCHE SOUND BAR CONNECTED TO AN LG TV
If the sound bar has optical connection I would hook up to tv that way. I had to do that with my lg and sound bar. Hope this helps. Good Luck.
Mar 27, 2013 | Klipsch Power Bar Soundbar with Wireless...
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
