Question about Memphis Car Audio & Video
Memphis 16-mcd1000 amplifier keeps getting hot and blown the internal fuses
3 Suggested Answers
  • 80 Answers
SOURCE: i have a new memphis pr 1000 and when u put power
Sounds like a grounding problem. Possibly internal.
Posted on Feb 18, 2010
deborahro14410
SOURCE: amp keeps blowing internal fuses on a memphis 16-mcd1000
got pyle pta 3000 watts dj power amp when turn on my power light indcatior light dont work but it still runs
Posted on Dec 31, 2013
Amp keeps blowing internal fuses on a memphis 16-mcd1000
Dec 31, 2013 | Car Audio & Video
I have a 800 watt sony amp pushing 2 memphis pr's should the amp get hot
Yes the amplifier will become very warm or "hot". It is a good idea to place it in an area that will recieve plenty of ventilation and air flow. Some companies sell cooling fans for larger amps.
Jan 02, 2013 | Sony Xplod XM-554ZR Car Audio Amplifier
Unit does not power up. Opened unit and found fuse closest to power switch blown inside unit. Will replacing this fuse get my unit working again? If so, what would cause this fuse to blow? please help.
It is possible that the fuse was blown due to a surge and replacing it will resolve the problem, but I wouldn't expect it. Usually when the main fuse blows, the primary stage of the power supply has a problem and the replacement fuse will blow as well. This is not a cheap amp and I would suggest that it be checked by a service tech. A few quick measurements internally can determine the likely fault and should not cost too much as an estimate fee.
Please keep us posted.
Dan
Jun 22, 2010 | Sonance Sonamp 1250 12-Channel Amplifier
Amp getting hot sound distorted fuses blown wires not touching
make sure that you have installed a wire fuse inbetween your battery and your amplifier that is the most common reason for blown fuses. without that extra fuse your amp is getting a non limited amount of power from the battery.
Jun 02, 2010 | Kicker IX702 Car Audio Amplifier
I have a new memphis pr 1000 and when u put power
Feb 17, 2010 | Car Audio & Video
Fuses keep going out put new fuses and the same problem occures.
IT'S YOUR AMP I HAD A MEMPHIS 1200 WATT AMP AND IT DID THE SAME THING I FORGOT WHAT THE PART WAS CALLED BUT IT'S WHERE YOU PUT YOUR FUSE'S IN THE PROBLEM IS FROM THE INSIDE OF THE AMP. IT COST ME $200 SO IF IT'S WORTH IT FIX.
May 03, 2009 | Diesel Audio NS-1000 Car Audio Amplifier
When I hook power to my amp the protect light comes on.
when connecting or disconnecting 12v power dont let the screwdriver touch the screw in terminal and side of amp at same time it causes a short in amp send it in to the factory or it could be the internal battery is burnt out from crankin it to loud
Apr 13, 2009 | Car Audio & Video
My memphis amp keeps blowing fuses,what could be the reason?
probably is got a short on the power supply inside of the amplifier.
Mar 19, 2009 | Car Audio & Video
Ma audio hk 4000d
you have definately blown a output channel, or power supply. Send it in for warranty.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
Hey thanks alot for the help, the way its hooked up now the amp eventually gets way to hot and the shut-off saftey heat switch just comes on. wondering if you had any suggestions for a good amp along with...
I would definately say, in the world of amplifiers you usually get what you pay for. I would recommend getting a Memphis or MTX amplifier. Go to ebay, specifically search for memphis then in the search options make sure to put in mono or 1 channel. All memphis mono block amps are 2 ohms stable. In particularly I would recommend for you the PR series. it is the Power reference series and they are really boomy for the money. Anything that has the "ST" is getting a little old so I wouldn't recommend it but It still is a good amp, just not sure how long it would last and how badly it's been beaten in the past. Good luck. If you find an amp and are unsure let me know which one and I can help verify it for you.
-Andrew Hawkins
Aug 30, 2008 | Legend LA1490 - American Legacy Series 2 -...
Car Audio & Video Logo
63 people viewed this question
Top Memphis Car Audio & Video Experts
Tygh Duval
Tygh Duval
Tom Chichester
richard foulk
Are you a Memphis Car Audio and Video Expert? Answer questions, earn points and help others
