Question about Samsung Audio Players & Recorders
Dvd home theatre system
My dvd player turns on then says protection and turns off
  • 11 more comments
  • rquigley3 Mar 21, 2008
    Help, I have the same problem.
  • cardosopaulo May 22, 2008
    my dvd player turns on then says protection and turns off
  • mtzero Jul 13, 2008
    after turning ON display says hallo and than protection. and it turns off
    my e-mail mtzero@o2.pl
  • Anonymous Oct 03, 2008
    Same problem here...
  • courtnash Nov 17, 2008
    I have the same problem>>. Has your's been resolved?
    my email address is courtnash@gmail.com
  • a_j_vargas03 Nov 23, 2008
    turns off after 5 secs and says protection
  • Anonymous Nov 30, 2008
    The same here....
    e-mail:luis_baixista@hotmail.com
  • Anonymous Dec 06, 2008
    I too have same problem -arakuking
  • Anonymous Feb 12, 2009
    same with mee
  • floodman Mar 19, 2009
    same here... anyone knows hot to solve it?
  • j_udermann Apr 11, 2009
    after about 5-6 minutes the entire system will shut down and say protection...
  • yyyyeeeessss May 03, 2009
    switches off after 5 mins any suggestions?
  • Anonymous Mar 14, 2014
    how do you turn off described video on dvd home theatre
    Sniper:
  • 70 Answers
Samsung HTS units have a heat protection mechanism.
Basically the unit shuts itself off to avoid overheating and further damage.
Reasons for this:
Unit's internal cooling fan may need to be replaced
OR
The unit may be sitting on another device (cable box, etc)
OR
The unit may not have adequate space at the back of it.
You can try:
Letting the unit stand alone. No device should be below it. Make sure it has adeuate space on its rear.
If those don't work the unit needs repair.
Hope this helps!
Posted on Jun 25, 2009
When I turn on my DVD it says "welcome to samsung dvd, no disk, protection, good bye" Why? What is wrong and how can I remedy it???
Posted on Nov 24, 2008
4 Suggested Answers
SOURCE: my dvd home theatre system ht tx75 keeps shutting down
I didn't solve the problem,however i called sam sung and I will be sending it in for repairs under warranty.
thank you
Posted on Jan 28, 2009
  • 4 Answers
SOURCE: DVD Home Theatre System Panasonic xv htd-330 dvd won't play
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on.
Posted on Mar 12, 2009
  • 40 Answers
SOURCE: I have bouight a samsung home theatre system that
You have several ways to do this. You can hdmi cables from the two units and plug them into your tv if it supports hdmi and run the audio out portion on the back of the tv and hook that into one of the audion inputs on the surround unit. Or you run audio directly out of the bluray using rca, digital coax, or digital optical cable. Turn the surround reciever to the corresponding input that you choose to use.
Posted on Jun 19, 2009
'No disc' message on Samsung DVD home theatre system
hello,
the problem the disc is samsung DVD home theatre is having is the lense that is weak. if yo replace the lencse then it wold work properly.
Jan 04, 2010 | Kenwood DV-6050 Multi-disc DVD Player
Decoding my RCA DVD player
Some players are harder than others to do this but you may want to try here or here
Sep 14, 2009 | RCA RTD255 DVD Home Theatre System System
I have bouight a samsung home theatre system that comes complete wiht a DVd player - i also have a samsung blu ray player - naturally ithought they would be compatible!! how wrong i was!! the connections...
Jun 19, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
My dvd home theatre system ht tx75 keeps shutting down
thank you
Jan 27, 2009 | Samsung 1200W 5.1-Ch. XM-Ready Home...
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
I am missing some parts
Jvc home theatre system cable that connects the the bub and the dvd
Jul 04, 2008 | JVC TH-M606 System
My home theatre system (sAmsung DVD home theatre system HT-Tx75)shuts down automatically after 10 minutes of listening to the radio...it says 'protection', then shuts off. i checked to see if it was on...
Protection mode on a Samsung player most likely means that the unit is overheating due to a non or low functioning fan. Before taking it somewhere to be serviced turn the unit on and see if the fan in the back is functioning (it should be on whenever the unit is on). If it is not you can try gently blowing it out with a can of compressed air.
I am sure that you can have it serviced but it might be cheaper to purchase a new player.
Good luck and take Care,
-WN
May 06, 2008 | Televison & Video
We are trying to watch a movie on our new ht-tx72 dvd home theatre system...but it keeps shutting itself off and saying protection goodbye....what can we do to fix this?...it is getting frustrating now
Your ICs audio amplifiers are in short circuit thats why that legend are coming for protect your theatre of more damage you got to replace the ICs.Good luck
Apr 13, 2008 | Televison & Video
1,918 people viewed this question
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
