Logitech z323 power supply faulty. what is the output voltage ?
SOURCE: How to check the PSU for IP3000 printer
I've just checked mine as it suddenly stopped working - does not even light up the green button.
I'm getting 8 volts Red to Black and 23 volts Red to Yellow so I guess it's fubared?
Posted on Jan 28, 2008
ginko
  • 19396 Answers
SOURCE: DELL POWER SUPPLY TYPE PS-5201-5D REV.F
230 Watts.
Here are specs and replacement:
230W ATX Power Supply - PS-5201-5D - HP-233SNF ...You can also replace it with a compatible 300 W psu.
Posted on May 27, 2008
welcomejee
  • 10594 Answers
SOURCE: power supply
if you are in usa, you need 1-468-809-11 POWER UNIT input ac 110 volt and output 8.5volt dc
and if you are in uk, then
1-468-811-11 POWER UNIT input ac 220 volt and output 8.5 volt dc
bye.
Posted on Sep 08, 2008
  • 12 Answers
SOURCE: power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Posted on Sep 22, 2008
Benimur
  • 6966 Answers
SOURCE: no output from power supply
I am assuming that you are very familiar with electronic circuitry and components, use of a DVM and a soldering iron. In the absence of a schematic diagram, and since you have perform initial voltage checks, perhaps you can wing it. Your "brick" will have to follow the basic design of an SMPS (switch mode power supply). Simply stated,an SMPS is an AC to DC to high freq AC then to lo V DC converter. Per your post, you have checked that there is DC (B+) from the AC mains, then what is needed is to check if there is oscillation to produce the high freq AC. Often design calls for an optical coupler, a small rectangular looking component with four pins, two at each end. This is nothing more than a LED and a Light Dependent transistor. Its function is to switch/trigger on the oscillation (and therefore start the SMPS producing the lo B+s).
Again, since there is no readily available schematic diagram, might I suggest that you post back the part numbers of the ICs and transistors. What we can do is pull out their spec/data sheets and/or application diagrams. Such would give us a general idea of the working voltages at what pins and what each component is supposed to do. Example, let us say your power supply uses a 817A/0635 opti coupler and/or an SG5841DZ controller IC, then we can search for them as initially described.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 30, 2008
How can I connect TV female SPDIF output to Logitech Z323 speakers?
SPDIF is digital -you would need to connect to a digital amp before the speakers.
Feb 27, 2015 | Sharp Televison & Video
Left speaker not working
This has just happened with my Logitech Z323 left speaker. I wanted to know if you were able to fix the issue?
Feb 08, 2014 | Logitech Z323 2 Speakers
Logitech speaker system z323
Unfortunately, manufacturers have decided we no longer need analog audio output jacks. I will never understand why. They do however still include an optical audio output connection. Go on Ebay and look up optical to analog audio output adaptor. Should run you about $20. You may also findnone at Best Buy but will set you back $60. Be sure to set the TV settings to PCM audio output. Otherwise you'll get no sound.
Dec 29, 2013 | Logitech Audio Players & Recorders
Any suggestions where to get a replacement volume knob for a logitech z323?
You can contact Logitech Team at the following # :
1-800-231-7717
Monday - Friday, 6:00am - 6:00pm PST
Saturday - Sunday, 7:00am to 5:00pm PST
Mar 05, 2011 | Logitech Z323 2 Speakers
What voltage power supply do need for the momo force feedback wheel i go one second hand and it was missing the power supply please could help?
Hi, Here all the specs of the Power adapter you looking for. Thanks and have a nice day ! J -
- Adapter model: ADP-18LB C
- Adapter Input: 200-240 V / 50-60 Hz ~ 400 mA
-Adapter output: 24.0 V - 0.75 A Output Plug - Outside Diameter (mm): 5.50
- Output Plug - Inside Diameter (mm) : 2.10
-Output Plug - Barrel Lenght (mm) : 12.00
- Output Plug - Polarity : Center positive.
thanks and have a nice day J -
Mar 30, 2010 | Logitech Momo Force Racing Wheel PC
To low output voltage 4.12 V pdp-121p
you power supply may be faulty or, or you motherboard, even try to update the bois
Oct 08, 2009 | Compaq 220W Power Supply for PDP-121P...
Logitek transformer for force 3D
The power supply is Logitech Model # GAD-SLU-240A8 P/N 190057-1000 OUTPUT IS 24V-----0.75A The output connector is positive center, negative outer ring.
Oct 02, 2008 | Logitech WingMan Force 3D Joystick
Will not turn on.
  • proceed as given after your power supply is ok (your statement)
  • isolate power supply from h/output stage.
  • check diodes & capacitors connected with flyback transformer.
  • check for print short.
  • ckeck h/output transistor.
  • connect supply to h/output stage.
  • put on the set.
  • hope this will help.
  • good luck
still there is a drop in voltage then your fly back transformer faulty.
Oct 12, 2007 | RCA F32450 32" TV
224 people viewed this question
 Grubhead
Grubhead
