Question about Logitech Audio Players & Recorders
Logitech diagram what would the output voltage of a z323 power supply please
SOURCE: Lost ac power supply adaptor for Mli 190 speakers
http://an-labs.com/multi/sw190.html 12vac
Posted on Jan 22, 2007
  • 12 Answers
SOURCE: power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Posted on Sep 22, 2008
SOURCE: adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Posted on Jan 14, 2010
SOURCE: Just wondering what the power supply output JBL Media 3 Speakers
I have JBL Media 3 Speakers running on the factory supplied power supply and the label states: JBL POWER SUPPLY, Model No. DV-9319B, Input: 120VAC 60Hz 35W, Output: 13.8VDC 1.7A, UL Listed3T58, E148325, CSA LR99152, Power Connection Diagram shows, Ring: Negative, Tip: Positive, CAUTION: INDOOR USE ONLY
PERSONAL NOTE: The power supply DOES NOT have the AC plug on the back. It is big hefty black block with an attached AC cord on one side and an attached DC cord on the other. My speakers are mounted high on the wall and run at approx.90% of full volume with Bass & Treble set flat. Actual volume and EQ settings are controlled via the sound card software based "Mixer Panel".
Posted on Apr 15, 2010
  • 961 Answers
SOURCE: my Logitech Z323 2.1 Speakers
Is it internal or USB?
Posted on Mar 25, 2011
How can I connect TV female SPDIF output to Logitech Z323 speakers?
SPDIF is digital -you would need to connect to a digital amp before the speakers.
Feb 27, 2015 | Sharp Televison & Video
Left speaker not working
This has just happened with my Logitech Z323 left speaker. I wanted to know if you were able to fix the issue?
Feb 08, 2014 | Logitech Z323 2 Speakers
Logitech speaker system z323
Unfortunately, manufacturers have decided we no longer need analog audio output jacks. I will never understand why. They do however still include an optical audio output connection. Go on Ebay and look up optical to analog audio output adaptor. Should run you about $20. You may also findnone at Best Buy but will set you back $60. Be sure to set the TV settings to PCM audio output. Otherwise you'll get no sound.
Dec 29, 2013 | Logitech Audio Players & Recorders
Any suggestions where to get a replacement volume knob for a logitech z323?
You can contact Logitech Team at the following # :
1-800-231-7717
Monday - Friday, 6:00am - 6:00pm PST
Saturday - Sunday, 7:00am to 5:00pm PST
Mar 05, 2011 | Logitech Z323 2 Speakers
What voltage power supply do need for the momo force feedback wheel i go one second hand and it was missing the power supply please could help?
Hi, Here all the specs of the Power adapter you looking for. Thanks and have a nice day ! J -
- Adapter model: ADP-18LB C
- Adapter Input: 200-240 V / 50-60 Hz ~ 400 mA
-Adapter output: 24.0 V - 0.75 A Output Plug - Outside Diameter (mm): 5.50
- Output Plug - Inside Diameter (mm) : 2.10
-Output Plug - Barrel Lenght (mm) : 12.00
- Output Plug - Polarity : Center positive.
thanks and have a nice day J -
Mar 30, 2010 | Logitech Momo Force Racing Wheel PC
No voltage output
Would recommend replacing this unit instead of serrviceing it yourself it will cause adverse effect and may even smoke. These units once they dye there gone. If you need a diagram I would direct you to www.apex.com.
Apr 22, 2009 | HP Bestec ATX-1956D 200w HP Part No...
Power supply for logitech driving force steering wheel
It's OK to use a power supply with a bigger current capacity than needed. If you find once with, say, 24V and 1.0A then that's usable - the wheel will draw as much as it needs.
Therefore:
Same voltage (24V)
Same or greater current (=>0.75A)
Same polarity (positive centre) __________________
Same as the Momo Racing Black, positive inside, negative outside.
The G25 power supply output is stronger: 24Vdc, 1.75A, same polarity.
As long as output voltage, polarity, amperes and connectors are the same you should be fine using a compatible unit, if you find one. In your case it would be 24V, 0.75A, positive inside, but if I were in you I'd wait for some American Driving Force owner to confirm this to be completely sure. The American psu model should however be GAD-SLU-240A8, 110V input, same PSU as Driving Force Pro. Take a look at this for more info. I received this from a forum with people that had the same issues as you and I hope this helps. It seems like they're saying that a store bought universal power supply may mess up your wheel so be careful. If this helps, please leave feed back. FIXYA!
Feb 14, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
Logitek transformer for force 3D
The power supply is Logitech Model # GAD-SLU-240A8 P/N 190057-1000 OUTPUT IS 24V-----0.75A The output connector is positive center, negative outer ring.
Oct 02, 2008 | Logitech WingMan Force 3D Joystick
140 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
